I would go with 10w40 semi-synth in this case.
Always replace oil filter.
But...if PCV is clogged...it will smoke.
PCV test first!
Volvo 850 10v to 20v Conversion.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
2ndGenVolvos
- Year and Model: 1996 850
- Been thanked: 2 times
Oil filter is brand new, actually. But typically blue/grey smoke is an indication that the motor is burning oil, and given the valve stem seals often go bad on these cars that would be my first assumption. Of course, I haven't done a thorough look over and I've just fiddled with the car for a day or two. But given that the head will more than likely need work (due to overheating and burning oil) I'm going to do some serious research into the schematics of both the 10v and 20v motors and see if its possible to run a 10v head with the stock ecu. If not, I might just swap out the sensors and the harnesses and the ecu and proceed with the 20v swap.scot850 wrote: 06 Apr 2022, 09:22 I would also remove the spark plugs and have a look at the plugs for condition. They may give an indication on what is happening in the cylinders. Then do a compression test.
Are you sure the smoke is oil and not fuel? Does the temperature gauge read correctly?
Try changing the oil. If someone used too thin an oil, then it will blow by the pistons into the combustion chambers. Put a fresh oil filter in and try filling with 10W-30 high mileage oil and see if there is a difference.
2ndGenVolvos
Yes as soon as I have time I will definitely do a PCV test. No point taking the motor apart if I have to clean the PCV anywaymisha wrote: 06 Apr 2022, 09:38 I would go with 10w40 semi-synth in this case.
PCV test first!
2ndGenVolvos
Okay!
After lots of forum digging I've found that, mechanically, this conversion is possible.
I'll need the 20v head, exhaust manifold and intake manifold from a 20v engine, and pistons from a 20v engine as they have 2 releases for the valves.
My question now, however, is this: Is it possible to run these parts without having to swap out the ECU from a 20v car? Of course, this would also mean that I'd need to have sensors, harnesses, etc. swapped out as well.
2ndGenVolvos
Well,2ndGenVolvos wrote: 06 Apr 2022, 15:04 Okay!
We've found the answer to the ECU question.
The 20v head uses electronic fuel injection which means that we will need an ECU. This means all the engine management sensors will need to be replaced as well, and any relevant harnesses. FUN
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The harness splits at the ECU box. If you have the engine side of the 20V harness from an appropriate donor, that should get you most of the way there. Compare the "A" and "B" side pinouts of the ECUs. "A" is the engine side and "B" is the body side.
The body side *should* be pretty much the same.
What system is your 10V using? One of the Fenix ones?
2ndGenVolvos
Yes, it's got the Fenix Siemens 5.2. I think I can find an ecu and harness fairly easily. There is an 850 in a junkyard up the road from me that I'm going to check out. Fingers crossed everything is there and in good condition. Although, I should be able to find an ECU on ebay fairly simply. The harness I may be able to get a brand new from Volvo. I'll need to look into that. Sensors are easy enough, just a pain in the ass to swap out.Chuck W wrote: 06 Apr 2022, 19:40 The harness splits at the ECU box. If you have the engine side of the 20V harness from an appropriate donor, that should get you most of the way there. Compare the "A" and "B" side pinouts of the ECUs. "A" is the engine side and "B" is the body side.
My dad wanted to try to run the 20v head with the Fenix ECU but I don't think that is possible. I think the ECU wouldn't recognize the 20v injectors, assuming they're different than the 10v ones.
SirBrickWagon
- Year and Model: 1997 Volvo 850
- Has thanked: 7 times
- Been thanked: 11 times
i see you've come around to the turbo swap!abscate wrote: 05 Apr 2022, 04:39 Or swap in a 20V engine if you want the power! I think the turbo swap is feasible too, for the monkey wrencher
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
10V aka Fenix 5.2 uses fuel injection exactly same way as Motronic.2ndGenVolvos wrote: 06 Apr 2022, 18:38Well,2ndGenVolvos wrote: 06 Apr 2022, 15:04 Okay!
2ndGenVolvos wrote: 06 Apr 2022, 22:26Yes, it's got the Fenix Siemens 5.2. I think I can find an ecu and harness fairly easily. There is an 850 in a junkyard up the road from me that I'm going to check out. Fingers crossed everything is there and in good condition. Although, I should be able to find an ECU on ebay fairly simply. The harness I may be able to get a brand new from Volvo. I'll need to look into that. Sensors are easy enough, just a pain in the ass to swap out.Chuck W wrote: 06 Apr 2022, 19:40 The harness splits at the ECU box. If you have the engine side of the 20V harness from an appropriate donor, that should get you most of the way there. Compare the "A" and "B" side pinouts of the ECUs. "A" is the engine side and "B" is the body side.
Just use injectors from 10V?
ECU doesn't check Injectors on gasoline sides usually. Thats just DIESEL thing for the ex. Fords you need code them as because "common rail" tech or similar. On gasoline side i haven't end up to that in these year of models ever yet. ECU on these usually knows what size they are if that and thats it on petrol.
The issue if you run mixed injectors usually are that you get wrong amount fuel in the mix as it tries use different size what injectors originally was there.
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
My 10v 2.0 (fenix) had a MAP sensor, I think the 20v with motronic used a MAF sensor? That is something I would definitely check.
Pretty sure you can try to run it with the Fenix, but if you gain anything regarding power - who can say if that will work.
I hated the Fenix ecu as it is very hard to find a reader that will work with it. Shops where I live also can't read it any more (too old)
I would not do this, if you really are doing all this work just put in a turbo engine (or turbo the 10v
), then it is at least worth it. The 20v vs the 10v will most likely only have more power in the higher rev band. So if you don't plan to rev it beyond ~4k much then I don't think you will gain anything from this at all. But this is mostly speculation on my part, so maybe I am wrong
850 T5-R '95 auto
- 1666 Views
Last post by Clemens
- 3517 Views
Last post by mazzaw12
- 1189 Views
Last post by misha
- 1197 Views
Last post by jeffsws
- 2280 Views
Last post by Sommerfeldt
