There are only crickets in here...
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
I got an email that Classic Volvo Restoration has all the 122 bumpers back in stock. Brand now! All chromey and stuff!
Back in Stock.
Volvo Amazon 122/220 Bumpers
The original style bumpers are now back in stock.
Our 122 bumpers are made from steel and then chromed like the original.
Made from new tooling and pressed, laser cut, polished and chromed.
Fits all Volvo Amazon 122 from 1957-1970, including wagons.
You can find all bumpers for the 122 here.
If you have a P1800 S/E/ES you can find all 1800 bumpers here.
And if you have a PV 544/210 you will have to wait another month... Hint..
WHO doesn't like shiny new bumpers??
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
BlackBart
Post by BlackBart »
Sluta!! Du kör fort! Det är inte tillåtet! Du är arresterad!
(lame attempt with google translate)
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
BlackBart wrote: 11 Apr 2022, 10:35 Sluta!! Du kör fort! Det är inte tillåtet! Du är arresterad!
I think I get the point.
Busted.
BlackBart
Post by BlackBart »
I ran across a page for the Apple Farmer Racing Team, which is based in the US Pacific Northwest, and ran a highly prepared 122 coupe in the historic La Carrera Panamericana race which runs the length of Mexico (or it did in the early days, maybe not now). They had some great mechanics, obviously the owner / driver, and Phil Singher of VClassics Motorsport - the wizard of B18 / B20 cylinder heads - was part of the build team.
http://www.applefarmerracing.com/car.html
Modified crank for less friction, aluminum & steel timing gears, electronic ignition, lightweight flywheel, Isky lifters / pushrods / valve springs, ARP hardware, 4-2-1 header, custom intake for BIG 48 Weber carbs, Ross 11:1 pistons, head porting, Schneider Racing cam with wide torque band, all producing big torque, high altitude reliability, and 7500 rpm redline.
Chassis was reinforced, a full cage built, 1800E limited slip rear axle with ratios changed, 1800 front hubs and brakes, Ipd sway bars, overdrive transmission with 1800 shifter, one-piece driveshaft, VPD (?!?) street performance springs for rough roads, poly bushings, Willwood 4-piston brake calipers, Cibie lights, .
Apple Farmer 122.jpeg (256.23 KiB) Viewed 945 times
This is interesting - they needed big air horns on the carbs. This don't fit inside the fender, much less with a filter. They built an airbox, cut out the fender wall, and patched it. Because the remote oil filter blocked the path to a forward intake, they ran hoses to a filter box where the battery was, then up to the cowling vents where there's positive pressure.
Apple Farmer air box.jpeg (258.26 KiB) Viewed 945 times
Apple Farmer - Oddvar modification.jpeg (235.94 KiB) Viewed 945 times
They had clutch problems and the gearbox had to come out.
Apple Farmer - out with the gearbox.jpeg (185.65 KiB) Viewed 945 times
Apple Farmer hair.jpeg (194.35 KiB) Viewed 945 times
Apple Farmer magazine.jpeg (132.41 KiB) Viewed 945 times
Apple Farmer crew.jpeg (253.04 KiB) Viewed 945 times
Apple Farmer nose.jpeg (311.27 KiB) Viewed 945 times
Apple Farmer on the move.jpeg (280.53 KiB) Viewed 945 times
Apple Farmer OO.jpeg (271.73 KiB) Viewed 945 times
Apple Farmer program.jpeg (213.58 KiB) Viewed 945 times
Apple Farmer waiting.jpeg (319.13 KiB) Viewed 945 times
Apple Farmer start.jpeg (209.62 KiB) Viewed 945 times
Apple Farmer.jpg (222.6 KiB) Viewed 945 times
Class win!
Apple Farmer checkpoint.jpeg (254.39 KiB) Viewed 945 times
Apple Farmer class win.jpeg (204.48 KiB) Viewed 945 times
Apple Farmer win.jpeg (137.58 KiB) Viewed 945 times
BlackBart
Post by BlackBart »
Apple Farmer little.jpeg (145.59 KiB) Viewed 945 times
BlackBart
Post by BlackBart »
Then one year they went to Pikes Peak! There's no messing around on Pikes Peak.
Don't Go Off
APple Farmer - don't go off.jpeg (202.47 KiB) Viewed 944 times
Apple Farmer Pikes Peak prep.jpeg (219.27 KiB) Viewed 944 times
Apple Farmer Pikes Peak.jpeg (227.24 KiB) Viewed 944 times
Fascinating!
matthew1
Site Admin
Post by matthew1 »
Racing in MX would be an incredibly fun thing to do. In the 90s I drove a (crappy by today's standards) sand rail in Baja on the terrain (maybe actual trails) of the Baja 500/1000 courses. Of course this isn't the same as road racing, but from being down there so much in my youth I can tell you the scenery and people are off the charts.
Here are some vintage 80s-90s Baja 1000 posters I found in an ice cream shop in San Ignacio last summer when I took my son down there. The owner is a big fan and friends with some of those drivers.
Also -> Amazon link
BlackBart
Post by BlackBart »
When I was a kid, we loved Broncos. My dad had one, my first car was a beater Bronco I put a new engine in with my Montgomery Wards socket set, and my old brother had one.
So I loved the Bill Stroppe Baja Broncos, which were essentially tube-framed race cars with a Bronco body fabricated onto it. They were Ford factory supported. Parnelli Jones did a lot of driving and winning.
