1998 2.5t MAF correct flow
radek93
Year and Model: S70 98
Has thanked: 2 times
Been thanked: 3 times
Post by radek93 »
What is the correct air flow values g/s in B5254t?
radek93
Post by radek93 »
Or similar engines.
Has thanked: 1609 times
Been thanked: 4065 times
At idle I want to say something like 2-3 g/second
I think I wrote this up somewhere , too
….found it
radek93
Post by radek93 »
The lowest value in the photo is 17.9 kg / h, which is almost 5 g / s. I have checked out of 5 used flow meters and none showed more than 3.6 g / s. The inlet is tight, I checked it under pressure. It only hisses in the hole on the underside of an intelcooler that appears to be factory.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Me7 & M4.3 or M4.4 doesn't have the same values.
Maf sensors are also different and NOT interchangeable!
You will need values for m4.3 or m4.4.
Me7 is from '99 and later.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
