I pulled a fuel pump out of a 99 T5 that had been in the yard since February. It's extremely clean and looks fine. It also looks dry to me, but the last ones I saw were covered with gasoline.
I want to have this as a spare on trips, so is it safe to test it quickly with it not submerged in fuel?
Seems to me I read something once that said you should NEVER do that because it would immediately damage the pump. I'd rather avoid filling up a bucket with gasoline applying electrical current to it, but that's not saying that I wouldn't do it...
Testing Fuel Pump Out of Car
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
- Has thanked: 311 times
- Been thanked: 817 times
I always quickly test them dry before installing, have done it several times with used pumps and for sure tested the one new pump I had to install last fall when the fuel pump went out a thousand miles from home. That one is still working. Didn't want to install a bad pump! I do it with every junkyard pump I pull when I get them home. Just briefly apply the voltage, carefully touch the wires to the contact and see if it spins up. With no gasoline around!
My thinking is the gas is supposed to cool the pump, so just a momentary spin-up should be harmless.
- Has thanked: 2202 times
And for goodness sake put that cigarette out...........!
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Yes, the fuel is often designed to cool the pump as it flows through. I had a Scirocco pump vapor lock on a 100 degree day and it ate the pump in a matter of seconds.
- 9 Replies
- 7342 Views
Last post by Jeff Schubert
- 15 Replies
- 3120 Views
- 793 Views
Last post by erikv11
- 42 Replies
- 12111 Views
Last post by Maestrours
- 5093 Views
Last post by wizechatmgr
