Vida CEM swapping
charlie13
Year and Model: 2009 XC70
Been thanked: 18 times
Post by charlie13 »
Do you have VBF CONVERT ver.3.7.0 and Volvo VBF tool thank you
[/quote]
Hello. Unfortunately, I don't. I am looking for myself but no one wants to share
charlie13
Post by charlie13 »
Only old if it helps?
VBF Tool 2.2.0.7z
(3.36 MiB) Downloaded 402 times
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
charlie13 wrote: 16 Apr 2022, 14:31 Only old if it helps?
Could use the older v1.X and newer v3.X
White papers on the VBF formats would be nice.
Active
Past
charlie13
Post by charlie13 »
I want to connect to table P3. The can contacts are in the blue plug. I am looking for power and minus. Will anyone help? May be priv
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
charlie13 wrote: 20 Apr 2022, 09:48 I want to connect to table P3. The can contacts are in the blue plug. I am looking for power and minus. Will anyone help? May be priv
This is what I had.
charlie13
Post by charlie13 »
vtl wrote: 20 Apr 2022, 12:00
This is what I had.
Thank you. See my attachment. I have a CEM M32C + 95320. Your description is R5F64524 / R5F64525
ford bcm wiring diagrams.pdf
(556.85 KiB) Downloaded 482 times
alevol
Year and Model: 2005 S60
Has thanked: 6 times
Been thanked: 3 times
Post by alevol »
vtl wrote: 13 Apr 2022, 14:46 Let us know how it goes.
Cracking about 2h now.
SEED 90 0f f5, PIN 00 01 11 45 47, KEY 42 1e 44, 235 pins/s
If there were ways to accelerate the speed... SMOK.pl promises 0...10h to crack. Some tools claims 4-6h. They must be using different approach. Or better hardware maybe?
charlie13
Post by charlie13 »
alevol wrote: 21 Apr 2022, 05:58
Still counts. I have a UHDS and an I / 0 terminal. UHDS counts slowly, I / 0 terminal does all CEM P1, P2, P3, SPA. That's why I / 0 is the better tool for me.
wormland
Year and Model: 2007 XC90
Has thanked: 13 times
Post by wormland »
Speed depends on which P3 CEM they are referring to. 2008-2010 is slowest. And then 2010-2014. Fastest is 2014-2017.
gooroo
Year and Model: XC70 2005
Post by gooroo »
No idea if this is what you wanted....?
Regards, Simon
VBF-convert-to-BIN.zip
(820.78 KiB) Downloaded 302 times
