High beams not working.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
No matter what position the light switch is in, the high beams do not work. Thy do not work in the flash position (one forward with the stalk) or in the steady position. I see the blue high-beam light come on on the dash, and I can hear the relay clicking. At first they seemed to work intermittently, but now they are not working at all. If I move the stalk forwards and backwards a bunch of times, the high beams do seem to come on about 1/30 times. Once they are on, they do not turn off by themselves. I have also tested both bulbs with a multimeter, and they are fine.
How would I fix this?
2002 v70 X/C 288k miles
Been thanked: 504 times
Post by cn90 »
Get a used stalk from junk yard ($10) or ebay ($25) and use it to test.
Common problem is in the stalk.
Easy job, once the upper cover is lifted up, only 2 Torx screws.
Tons of info in forum...
02V70
Post by 02V70 »
Would a broken stalk still make the high beam light on the dash light up?
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Check the fuse? Does it get the voltage with the beams on?
02V70
Post by 02V70 »
Do I test voltage by taking the fuse out, and putting a multimeter where the fuse's pins were?
vtl
Post by vtl »
Yes. Unless the fuse has a metal contact on top, in that case you can test the voltage directly on the fuse.
iamhives
Year and Model: 2018 V90 T5 R design
Been thanked: 6 times
Post by iamhives »
In addition to the other suggestions which are probably more likely it still could be the relay despite it making a noise. Even though its clicking maybe its not making a good contact.
