Hi folks,
Somewhere in upstate New York, there is a clear lens lying roadside from the driver's corner light on the '97 850 base.
Using my VIN, FCP says I need Volvo part number 6808834. IPD says the OEM number is 6817769. Carparts says the OEM number is 68177690. The part seems to be listed variously as a corner light, a combined light, or a turn signal light.
Does anyone have advice on how to determine which I might need, and if I should get additional items- spring clip, receptacle, etc?
Thank you!
850 Corner light specification help, please
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I think, the difference is between single and dual bulb headlights. Each apparently uses a difference corner light... at least that's what I am thinking given what I've seen when looking at lights.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2210 times
This link may help. This shows 2 different types hence the different part numbers. What may help is the picture of what is behind the lamp to help identify which you have:
https://parts.volvocars.ca/a/Volvo_1997 ... 64936.html
- Has thanked: 1611 times
- Been thanked: 4073 times
I’ve got a couple of V70 lights, will those fit or does the sexy v70 curves ignore Mr Boxy 850?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
V70 ones are different.
Early 850 ones will also not fit('92-'94).
'95-'97 will.
'95-'97 will.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
Thanks, gentlemen. Car and I are separated by 350 miles. With your help I am getting closer to a solution. Car has two-lamp headlight and the roughly 5” tall unit. Choices are narrowing!
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
I can look in local yard there are 850's there. Often these corners are missing or beat up. I expect to be there early next week, doubt I'll be charged more than a few bucks if I am lucky enough to find a good one. I can make sure it's complete with spring, etc. though yours is in place I'm sure. I think the fit of the e-bay versions is fine IIRC, however.
Isn’t she driving by Erie VoVo between North and SU?
- Has thanked: 312 times
- Been thanked: 818 times
A key part to look at from a junkyard, 850 corner light (aside from the spring) is the mounting tab, these are usually broken.
markone
I will check if she passes Erie VoVo, and those junkyard pro tips are much appreciated! I went ahead and ordered a new part from Eeuroparts. I have not been able to source the attaching spring, so I will have to be careful in the swap-out. Thanks again for your help.
- 254 Views
Last post by Wackneck
- 664 Views
Last post by erikv11
- 1511 Views
Last post by cn90
- 1968 Views
Last post by RickHaleParker
- 352 Views
Last post by kahl
