Vacillating Transmission Fluid Levels
miriamsully
- Year and Model: 2006 s60
My transmission fluid shows as being right where it should be when I first check it, but if I check it a second time it's an inch and a half further up the stick. I've been checking it with my car level and running, and I've been waiting until my car is all warmed up, but this happens every time I check the fluid level. Any idea what would cause that?
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
My 02 does the same, but reads in the lower cold range when first pulled out. After I clean the dip stick and reinsert it, it shows all the way to the top. I check it only after driving for at least 30 minutes and sitting perfectly level.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Air pressure buildup in transmission's oil sump. You want to check the level on the dipstick when the pressure is relieved. If it's 1.5 inches higher than indicated marks - it's definitely overfilled.miriamsully wrote: 26 Apr 2022, 20:50 My transmission fluid shows as being right where it should be when I first check it, but if I check it a second time it's an inch and a half further up the stick. I've been checking it with my car level and running, and I've been waiting until my car is all warmed up, but this happens every time I check the fluid level. Any idea what would cause that?
- 762 Views
Last post by adrian22
- 3774 Views
Last post by christhegamer
- 10 Replies
- 8671 Views
- 1247 Views
Last post by Krons
- 3563 Views
Last post by Krons
