850 Corner light specification help, please
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
markone wrote: 25 Apr 2022, 07:21 I have not been able to source the attaching spring, so I will have to be careful in the swap-out.
Smart. That spring is a little rocket!
Also -> Amazon link
Has thanked: 2215 times
Been thanked: 1853 times
Is the spring not part of the replacement unit? I thought they came with them.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Volvo ones do.
It seems that aftermarket ones doesn't.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rick4484
Year and Model:
Has thanked: 59 times
Been thanked: 10 times
Post by rick4484 »
My 96 850 has been sitting for some months and today I noticed the driver's turn signal light assembly dangling by the electrical wire. When I examined it closer I noticed the plastic part on the body of the light, where the spring attaches, was broken. I'm assuming the plastic was just brittle and the spring tension caused it to break. Online advertised cost of the part for genuine Volvo, #6817769, is somewhere between $64.00 and $120. eEuroparts has theirs for $28.64 each.
I thought about ordering one from a dismantler, but the problem with weathered plastic is you're getting something that would most likely be a short term fix. If the eEuroparts assemblies are a decent replacement, I think I would order and replace both sides.
I'd like to know how different the genuine part is from the oem part. Is there a difference in fitment, illumination, installation?
Has thanked: 1614 times
Been thanked: 4078 times
Get a $1 bungy cord from Harbor Fright and secure your signal to the frame with light tension
misha
Post by misha »
Genuine (oe) have Hella in the upper part and Volvo in the lower part.
Oem ones have just Hella or Valeo(same quality as oe just without Volvo lettering).
Some aftermarket ones comes without attaching spring,as our member pointed out.
Depo is good aftermarket replacement...don't know about other aftermarket brands...but if you stick with good known aftermarket brands it will be fine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
