P2 front wheel bearing Timken, SKF or FAG ? 31329980
Has thanked: 311 times
Been thanked: 817 times
I finally need to do a hub bearing, front left on the 07 XC70.
I know Timken, SKF or FAG are all good quality, but they also always price out like thi$:
Timken > SKF > FAG
FCP site says all three are OE for the 07 P2.
Is Timken really higher quality than the other two - opinions?
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Very happy with my SKG rear bearing that I replaced in 2019. Just my 2c. Good price on Rockauto.
04s60 2.4
04xc70 2.5t
br0dy519 wrote: 12 May 2022, 21:20 Very happy with my SKF rear bearing that I replaced in 2019. Just my 2c. Good price on Rockauto.
Good to know, thanks.
Yep that's where I was going with this - Timken @ RA is same price as FAG @ FCP. I can risk the warranty disadvantage on this one.
Been thanked: 4065 times
I’ve used FAG for all my hub replacements, N= 6 on various S/v70
I may have done one replacement/ replacement with about 120k on it
Don’t forget to add the internal seal, if applicable
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
FAG.
For SKF check the country of origin. P3 Volvos are plagued with SKF not-Sweden.
Timken is (was) also known to be good. I haven't used their wheel bearings in particular, but alternator bearings with the right index (high-temp, high-speed) are top notch,
Has thanked: 2200 times
Been thanked: 1852 times
Timken used to be a good brand, just like SKF when they are made in Europe. Same can be said for FAG. Can't speak for non-Europe made items.
I ordered one, went with FAG.
abscate wrote: 13 May 2022, 02:51 I’ve used FAG for all my hub replacements, N= 6 on various S/v70
Affirmative on the dust seal.
Can I also access/swap the ABS tone ring during this job, without removing the axle? They are pretty rusty, have replacements in the garage already.
br0dy519
Post by br0dy519 »
erikv11 wrote: 13 May 2022, 12:49 I ordered one, went with FAG.
Definitely. I did both my fronts without axle removal. But they already failed and fell straight off. You might have to dremel yours off carefully. Clean off the axles mating surface well with a wirebrush. My indy says put green permatex on the surface but I just heated my new tone ring up in the oven and used the old one to set the new one in gently but firmly, kind of like when youre replacing a bearing or seal. Good 3 years later still.
I don’t recall needing to put on a dust seal on my SKG. Hope I didn’t set myself up for another failure.
04s60 2.4
04xc70 2.5t
Been thanked: 504 times
Post by cn90 »
I always used FAG bc they have good reputation.
SKF and Timken are also good brands but as above, watch for QC issues.
Bearing job is usually involved, so I play safe and stay with FAG in my BMWs and Volvos...
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I like SKF. Maybe because they are or where (?) swedish from the beginning anyway. Svenska Kullager Fabriken :)
BMW 540i 2002
S70 Base 2000
