96 850 Turbo: Codes P0302 P1310 - problem ONLY during idle
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Remove negative battery cable for 10-15min in order to reset fuel trims and clear the codes.
Codes will not clear themselves after replacing parts....they should...but only after a few driving cycles....depending on what fault codes were stored.
If the codes come back....we will proceed further.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
Year and Model: 1996 850
Post by insession »
10/4 misha. Usually I clear the codes with my OBDC reader, but have just tried your method as well.
misha
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
Post by insession »
I have now, thanks misha. So many possibilities!
insession
Post by insession »
One more observation: the engine, under the hood, looks a little shaky when in idle, but becomes static/stops moving once the rpm are 1500 or so and above..
Has thanked: 1609 times
Been thanked: 4065 times
That’s a textbook description of a missing cylinder. At higher revs the missing cylinder vibration matches another cylinder firing so you don’t feel it, speaking loosely
insession
Post by insession »
Thanks abscate - I take it the easiest to find out about that would be to disconnect one spark cable at a time and see which one may be the culprit?
misha
Post by misha »
After reading volvospeed post...i would perform a compression test first.
If that ends up ok...then i would chase ignition and injection system problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
Post by insession »
Sorry guys, have been busy or lazy ;-) Not gotten around to properly diagnosing this. Still same codes when idling in gear or crawling in gear ;-)
insession
Post by insession »
An embarrassing update ;-)
Pulled each plug wire to see if it would dramatically change idling. Found standing oil in #2 and #3, and both plugs loose. My bad entirely - last I regapped them, didn't have access to my wrenches, and borrowed a MOEN plastic plumbing deep socket that fit, and tightened it as much as possible. Clearly, not tight enough ;-)
Now that I did it on all plugs with the right tools, it idles less rough, though I'm still getting those two damn codes.
Wires sparked fine, and none of the pulled cylinders changed the idle in a way that would make one stand out over the others.
