Another oddity - the return line does not seem to connect to anything. Just dumps over the tank.
Is that where excess pressure is supposed to be returned?
2002 S60 high fuel pressure
wrgallant
- Year and Model: 2002 s60
- Been thanked: 2 times
Any idea why my pump is not releasing excess pressure? I’ve tried 3 different pumps all with the same result.vtl wrote: 13 May 2022, 09:56 There's a relief valve right inside the pump in your model year, it releases the excess of pressure developed by the pump.
"Car seems to run fine" - but very rich. It will throw a code, if not already.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Do you have an OBD-II scan tool? Check the fuel trims, both short term (STFT) and long term (LTFT). Report back. If the ECU thinks its too much fuel, it will move the fuel trims to compensate.wrgallant wrote: 16 May 2022, 19:01 Any idea why my pump is not releasing excess pressure? I’ve tried 3 different pumps all with the same result.
- 16142 Views
Last post by Richard99
- 682 Views
Last post by v70XCSteve
- 812 Views
Last post by 93Regina
- 667 Views
Last post by oragex
- 34 Replies
- 8678 Views
Last post by vtl
