Idle speed is 800
Mass air flow rate is 1.1lb/min at idle
2002 S60 high fuel pressure
wrgallant
- Year and Model: 2002 s60
- Been thanked: 2 times
I disconnected the battery because I read that you should reset fuel trim - new readings at idle are as follows
short term fuel trim 1.6%
long term fuel trim 0%
Mass air flow rate 0.4lb/min
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
The theory is you put a PEM-controlled pump into your older car that does not have a PEM.
ECM tells the PEM how much load is required for the pump, PEM adjusts its PWM duty cycle, the pump develops fuel pressure accordingly.
When PWM line is connected to constant +12V, the pump thinks 100% load is required and works hard, until an internal pressure relief valve is triggered, which happens at about 100 PSI. I remember seeing that number when ECM cuts the fuel sharply right on fuel injectors, and the pressure raises momentarily to about 100 PSI.
- 16110 Views
Last post by Richard99
- 679 Views
Last post by v70XCSteve
- 812 Views
Last post by 93Regina
- 667 Views
Last post by oragex
- 34 Replies
- 8666 Views
Last post by vtl
