Remove negative battery cable for 10-15min in order to reset fuel trims and clear the codes.
Codes will not clear themselves after replacing parts....they should...but only after a few driving cycles....depending on what fault codes were stored.
If the codes come back....we will proceed further.
96 850 Turbo: Codes P0302 P1310 - problem ONLY during idle
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Did you read this post:
http://volvospeed.com/vs_forum/topic/96 ... /#comments
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1611 times
- Been thanked: 4072 times
That’s a textbook description of a missing cylinder. At higher revs the missing cylinder vibration matches another cylinder firing so you don’t feel it, speaking loosely
- misha
After reading volvospeed post...i would perform a compression test first.
If that ends up ok...then i would chase ignition and injection system problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
- Year and Model: 1996 850
- Been thanked: 2 times
An embarrassing update
Pulled each plug wire to see if it would dramatically change idling. Found standing oil in #2 and #3, and both plugs loose. My bad entirely - last I regapped them, didn't have access to my wrenches, and borrowed a MOEN plastic plumbing deep socket that fit, and tightened it as much as possible. Clearly, not tight enough
Now that I did it on all plugs with the right tools, it idles less rough, though I'm still getting those two damn codes.
Wires sparked fine, and none of the pulled cylinders changed the idle in a way that would make one stand out over the others.
- 1531 Views
Last post by WhatAmIDoing
- 1657 Views
- 1211 Views
- 1676 Views
Last post by RickHaleParker
- 11 Replies
- 2042 Views
Last post by greg850r
