240 headlights not working Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
LisaL
Post by LisaL »
My daughter has a 92 240 sedan. No problem with the parking lights, but when you go to headlights all lights go off, including dash lights. High beams go on when you pull the light shift towards you,even when other lights are off. We relaced the switch, but still have the problem. Maybe a relay?
menglish27
Year and Model: 1989240
Post by menglish27 »
I experienced the same problem as above last night on my 89 240. Any ideas would be appreciated
Year and Model: 2001 V70
Has thanked: 339 times
Been thanked: 496 times
Post by volvolugnut »
Check each headlight supply wiring for crumbly wire and a short or broken wire. Also check the fuse. The high/low beam switch failed for me on a 240.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
