Robert did the experiment some years ago, mapped his 850 T5 temps during some track days, and sent the oil off to the lab. He says he saw no difference with the delete plate installed, and when he's working on a clients car, he refuses to replace the oil lines. He keeps a few plates in his toolbox for that very reason. I think he's harvested five or 6 so far in SoCal.bmdubya1198 wrote: ↑20 May 2022, 21:44Well the good thing is that you can rest assured that your oil temperature is regulated as Volvo intended. Not much more than that though lol.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
- foggydogg
I knew there was stuff inside the rust ball,
Several hours later, after getting the calipers and rotors off, I convinced it to become a well-articulated part of the parking brake system again.
- Has thanked: 304 times
- Been thanked: 517 times
That's good to know!foggydogg wrote: ↑21 May 2022, 11:05 Robert did the experiment some years ago, mapped his 850 T5 temps during some track days, and sent the oil off to the lab. He says he saw no difference with the delete plate installed, and when he's working on a clients car, he refuses to replace the oil lines. He keeps a few plates in his toolbox for that very reason. I think he's harvested five or 6 so far in SoCal.
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
I replaced one of the oil cooler line two years ago, I've spotted the other one leaking a few days ago so this time i'll be going block off plate (or not if I do a RN swap)
Did a bit more digging into my engine, she aint straight capt'n !
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Today, I put a little micro attachment on my shop vac and sucked up all the little puddles of oil in the crevices of my cylinder head around the spark plugs. I think this is just every little bit of oil I slopped around the filler neck when topping off the oil. Once it goes under that black cover, it's out of sight and mind. Pretty clean now.
All U.S. market models.
All running and on the road.
Yeah, that's a little twisty...
- Has thanked: 1505 times
- Been thanked: 3818 times
Someone took “ getting boosted” the wrong way…
- Goupil
Right now my guess is a failing wastegate actuator, not sure
The crank and rod bearings dont look too bad for a 360 000km (~220k miles), some wear but nothing worrying
Ah, so probably got entirely too much boost at some point.
