Rescuing Geronimo the 2000 V70
- Has thanked: 1611 times
- Been thanked: 4072 times
What was the verdict on the ps rack, Firefox? Was it a line ( cheap fix) or are the rack seals gone?
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Thanks for continuing to pull parts. How many short head lug bolts do you have? I'll be stopping by a specialty Volvo shop tomorrow to buy any that you don't have.abscate wrote: 28 Apr 2022, 02:47 I’m slowly filling the Maine box with parts again.
I’ve found a bunch of lug nuts with short heads. Rusty but will clean up nicely.
Brake bleeders
I think I have two intake VVT solenoids. Checking part numbers
Coolant reservoir bottle
HVAC damper motor NH…which one do you need? MCC or ECC? Part number best of course
Thanks for the O2 sensors. How can I tell which is front and rear, and confirm that they work before installing?
I'll have the owner buy Geronimo a nice new coolant bottle as a lower priority. The coolant light is permanently lit on the dash, so I assume it needs a coolant level sensor.
The power steering rack leak must have been from a hard line and gotten patched by the mechanic who did the inspection. The fluid level doesn't seem to be dropping. That's a huge relief and I can check/improve that repair much later.
My car needs the ECC HVAC damper motor for the floor vents. It may be part 9142629 on the left side of the center console, immediately below the left temp motor. Is that same part used for multiple dampers? VIDA gives me code CCM-322 "Air distribution damper motor Active too long" but doesn't tell me the part number.
FireFox31
Your 2000 uses the later air distribution motor which is a single motor driving both sides. There is a chassis break in 1999 for this; I think this is in the bastards thread
Snip
Snip
Climate control changes
In late 1998 the damper and temp control modules were replaced by a single motor (9134729)doing both functions on the driver side. This was used 1999-2000 then replaced on P2
Edited to 1999-00
- FireFox31
Geronimo got new spark plugs today. It had been running rough with pending cylinder 4 misfire codes. The old plugs had some deposits and cylinder 2-3 threads were oil stained from the leaking fill cap gasket.
Cylinder 4 electrode was slick black though its threads were dry. Why might that have happened? How can I prevent it from happening again?
I've attached a picture of the old plugs. I'm interested to know if you see anything which indicates issues I could address. Thanks.
FireFox31
- Has thanked: 2209 times
Possible issues are a leaking injector so getting too much fuel or poor ignition so bad/worn plug or cracked/weak coil.
Those are so dead I would not try to read anything into them. Wow!
Into the Calgary Box for the next Scottish Boot Sale!
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Are these 3-point style plugs what the factory installed? When I pulled mine, I was surprised as I had never seen plugs like this. I was assuming I'd find some standard looking Bosch plug.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
It's like shaver blades, more is better. I buy the ones with 6 prongs.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
There's a chance it's a valve stem seal issue, but I'm with Dr. Abscate on this, drive the fresh plugs long enough to see if it cures the stumble; if so/then go on.FireFox31 wrote: 25 May 2022, 19:30 Geronimo got new spark plugs today. It had been running rough with pending cylinder 4 misfire codes. The old plugs had some deposits and cylinder 2-3 threads were oil stained from the leaking fill cap gasket.
- FireFox31
Thanks for the input. The cylinder 4 plug fouling coincides with compression test low pressure readings during the first two cranks on that cylinder. I tested the compression 9/2021 before doing any work, with a failed ETM, after the car had sat for 6 months. The pressure readings for each cylinder (rows) for each crank (columns) were:
Cyl 1 2 3 4 max
1 110 145 165 180 190
2 120 165 185 195 200
3 125 165 185 195 200
4 40 135 170 190 200
5 110 150 170 180 185
Here's the video of the cylinder 4 compression test. That first crank sounds so much weaker than every other cylinder's first crank.
Does this low crank and fouled plug suggest any problem with cylinder 4?
Cyl 1 2 3 4 max
FireFox31
- 21 Replies
- 18183 Views
Last post by SOURDOUGHJIM
- 1618 Views
Last post by foggydogg
- 972 Views
Last post by precopster
- 534 Views
Last post by Billy031
- 1228 Views
Last post by NSFWaldo
