- Has thanked: 1836 times
- Been thanked: 1709 times
I hope so as I have been doing this with P80's for 25 years!
- Has thanked: 304 times
- Been thanked: 517 times
It is, just avoid the edge where mine is bent lol. It’s a structural part of the car, so it’s a good solid lift point.
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
That's exactly where I always put my jack stands. Much better than the plastic bumper....
1999 V70 GLT
1999 V70 GLT
- Has thanked: 927 times
- Been thanked: 999 times
I like modifications where you go to similar models and get alternate parts.
Seconded, this is where I lift with a wood block on top of the jack stand.
For safety reasons I try to avoid using blocks of wood between the jack stand and anything I am lifting. Although I am careful I have had instances of the wood breaking and slipping. Only time I use a piece of 1/2" is when carefully jacking the oil pan to check or replace the crank pulley motor mount.
I have thick rubber pads bought at Princess Auto up here that swap in place of my regular floor jack metal castellated lift pad.
These are just drop in items.
While I appreciate it is not what everyone can afford to do, I just bought a higher lift capability floor jack to lift my 4Runner as the regular 3 ton floor jack could not lift the car high enough to remove the wheels without using a piece of wood. I would have sold my old one but the new one is too big to go under the 'R'.
Please also always use jack stands under the car and do not rely on the floor jack to support your car.
- Volvebaker
- Year and Model: 1993 850 GLT
- Been thanked: 10 times
Replaced the ball joints and tie rod ends. Boy, what a world of difference!!
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I thought the ball joints were part of the control arms on these cars?Volvebaker wrote: ↑28 May 2022, 13:25 Replaced the ball joints and tie rod ends. Boy, what a world of difference!!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
I cleaned my rims again. Trying to get the buildup off. Last week I used Chemical Guys Diablo, which I've since read is better for maintenance cleaning of rims. This week I tried a Black Magic product and a Mother's foaming wheel cleaner. I used the Black Magic cleaner on all four of the rims, and on 3 it seemed to leave a bit if white haze, but did get more gunk off. I then did the front rims again, one with the Diablo, and one with the Mother's. They are getting better... which unfortunately, shows they're kinda beat up.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Volvebaker
I’ve got one of the earlier runs of the cars, which had removable ball joints. A ‘93. Considered by some to be a handicap to own, considered by me, an advantage. Minor differences all around but I honestly prefer most to the latter inceptions. But I love ‘em all454cid wrote: ↑28 May 2022, 17:40I thought the ball joints were part of the control arms on these cars?Volvebaker wrote: ↑28 May 2022, 13:25 Replaced the ball joints and tie rod ends. Boy, what a world of difference!!
