Going to start with the ABS module
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Apparently the car did not like the ABS module being messed with. After breaking the screws loose, I accidentally unplugged it when I flopped the cover over. When I went for a drive the RPM would crash if I let off the gas, and I'd hear a clicking (relays I assume) on the right hand side of the car. I unplugged it again and took a look at it, but didn't see any bent pins. I drove around the large block again, and it was better (no clicking), but the throttle was still a little wonky.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2210 times
They are challenging! Well done in getting them off. The last one I swapped out, the hardest bolt to reach someone had kindly damaged so the E5 socket would not fit it. Can't recall which size of regular socket I used but it managed to get it loose and I had spares to replace it.
Like abscate suggested, if they have locked the key in, the owner should be able to get a manual key made up that will allow the door to be opened without breaking it. The dealer should be able to do this.
454cid
It actually wasn't difficult at all, just the access. Between the inspection sticker and oil change sticker, I believe this car is out of Allentown, PA, but maybe spent time in AZ or Florida, or maybe a garage in PA. No rust!scot850 wrote: 02 Jun 2022, 23:10 They are challenging! Well done in getting them off. The last one I swapped out, the hardest bolt to reach someone had kindly damaged so the E5 socket would not fit it. Can't recall which size of regular socket I used but it managed to get it loose and I had spares to replace it.
I took the car out again tonight, and I got more of the odd throttle response, a CEL and the upward arrow. I checked codes with the 850obd2 app, and got P0123 (TPS) and it said something about the transmission, but I didn't see a specific code. I didn't hear the clicking relay sounds I heard earlier. I cleared the codes, and continued, and on my way home it behave fine.
I did have to push a transmission cable around a bit when messing with the ABS module screws.
I'm wondering now, if I even want a high mileage Volvo if my low mileage Volvo keeps acting weird.Like abscate suggested, if they have locked the key in, the owner should be able to get a manual key made up that will allow the door to be opened without breaking it. The dealer should be able to do this.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1611 times
- Been thanked: 4075 times
Usually getting a high mileage Volvo sorted is the purging of the crap parts cheap Scots have used instead of Volvo or good OE replacements.
454cid
Searching with Google it seems a bad TPS covers a lot of what my car is doing. I wonder if I can effectively clean it, with Deoxit.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
I'm not sure anything has been done to the 98... from what I see, broken stayed broken. Headlight wipers missing, fuel door missing (I did see it got tossed in the back, which is a plus), the paint is dirty like it's been sitting someplace and needs Larry Kosilla from AMMONYC to intervene.abscate wrote: 03 Jun 2022, 02:02 Usually getting a high mileage Volvo sorted is the purging of the crap parts cheap Scots have used instead of Volvo or good OE replacements.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
An unmolested old P80 is a great project. Just got back from my 15 mile morning run on the S70 AWD….” The Kat”
Needed major rehab on one system, the fuel system in the back, but looking at all the maintenance and mods done I’ve barely done anything else.
She zooms off the line and delivers 28 mpg at 55 mph, smooth as silk.
Just don’t start with something too crazy…..
viewtopic.php?t=95351&start=120
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Oops, I should have mentioned earlier that deep sockets are a challenge in that tight space; turbo cars have more stuff in the way, too.454cid wrote: 02 Jun 2022, 19:09On another note, all 4 of the E5 bolts, on my 850, broke loose with ease.... well after I was able to get the socket on the screws at that awkward angle. The lower front was the most difficult. I'll pull the module Sunday evening, and send it out.abscate wrote: 02 Jun 2022, 18:42 You won’t balloon a Volvo door. Find someone who knows P80 Volvos so they won’t damage it
I think shorter sockets might be easier for a couple of the screws, but whatever.
Odd that you're having driveability issues after that, maybe try unplugging and re-seating both connectors ? Sometimes the old-school trick of disconnecting the battery for a half-hour can get the computer to remember to behave.
Are yo using a reconditioned ABS module or a used one?
454cid
I'm getting the original reconditioned.... planning on sending it to Mattymoo. Yesterday, I just broke the bolts free.
I'm thinking it's the TPS causing issues.... or wiring, but I hope it's not wiring.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 11 Replies
- 7304 Views
Last post by Vovoroom
- 10 Replies
- 6117 Views
Last post by misha
- 1649 Views
Last post by Dzikiewicz
- 531 Views
- 2289 Views
Last post by yagger
