Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
oscilloscope wrote: 03 Jun 2022, 13:38 is codewarriror used too decompile the micro's ?
https://onlinedisassembler.com/odaweb/
urosm
Year and Model: 2015 Volvo XC70 D5
Has thanked: 10 times
Post by urosm »
duzi wrote: 03 Jun 2022, 08:08
urosm wrote: 01 Jun 2022, 15:13
I have PIN from this CEM because I read it with SMOK and found a PIN. So if you need it, I'll send it to you.
:?: I thought smok" reads only P3 platform.. you use UDS option in smok ?
I forgot to write... I read it with SMOK JTAG on the bench.
P3 platform can be read with UHDS SMOK.
Volvo 744 TDIC SOLD, 1989. ; 1997. - 2000.
Volvo 855 GLT + LPG Estate SOLD, 1996. ; 1998. - 2020.
Volvo V70 D5 SOLD, 2004. ; 2013. - 2021.
Volvo XC70 D5 SOLD, 2007. ; 2017. - 2021.
Nissan Pathfinder DRIVING, 2007. ; 2019. -
Volvo XC70 D5 DRIVING, 2015. ; 2021. -
Volvo XC90 D5 DRIVING, 2008. ; 2022. -
oscilloscope
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
vtl wrote: 03 Jun 2022, 15:13
thanks
oscilloscope
oscilloscope wrote: 03 Jun 2022, 16:11
thanks
hmm doesn't seem to find the micro mask 1L15Y. , i'll continue to ticker with the disassembler.
postoak
Year and Model: 2007 XC90 V8 Sport
Post by postoak »
Have any insights into modifying/hacking transmission software (would this be the TCM?) been made as a result of the extensive work done around the CEM? Specifically, modifying torque converter lock-up and slip parameters for TF-80SC's and their respective valve bodies. Pls forgive any repetitiveness of my question if this has already been covered. I'm slowly making my way through the pages/posts in this thread to see if this was discussed in the past.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
search.php?keywords=tcm&t=85611&sf=msgonly
Hello postoak and welcome. You can search within topics using this. This is what it looks like on desktop, mobile is similar.
Also -> Amazon link
alevol
Year and Model: 2005 S60
Has thanked: 6 times
Been thanked: 3 times
Post by alevol »
Testing P3 branch. On the bench works well, but today i have tried it on car.
Every 5-6 seconds or so there is something that interrupts the process.
p3_cem_get_seed: what? ID 95, 03 ff 00 40 00 60 60 00
p3_cem_get_seed: what? ID c5, 30 00 00 3f ff 18 00 00
One time there is problem with ID95 the other is with C5, Then Teensy is putting modules to prog mode and after 5-6 seconds there is a relay click or smth and the cycle repeats. Seems, that something is not in prog mode or wakes up. Does anybody have the same problem?
Code: Select all
canMsgReceive timed out, start 3606919898, now 3607519931, diff 600033
SEED 3c 04 36, PIN 00 00 c7 11 23, KEY 87 f9 d7, 63 pins/s
SEED 12 65 79, PIN 00 00 c7 14 80, KEY 41 bf 43, 861 pins/s
SEED 18 da cc, PIN 00 00 c7 17 dd, KEY 37 56 70, 861 pins/s
SEED 0b 79 7c, PIN 00 00 c7 1b 3a, KEY 44 49 8d, 861 pins/s
SEED ad 37 94, PIN 00 00 c7 1e 97, KEY 41 ad 73, 861 pins/s
Putting all ECUs into programming mode.
 === CEM-on-the-bench users: you have 5 seconds to apply CEM power! ===
canMsgReceive timed out, start 2397663910, now 2398263938, diff 600028
CAN_HS ---> ID=000007df data=02 10 82 00 00 00 00 00
CAN_LS ---> ID=000007df data=02 10 82 00 00 00 00 00
canMsgReceive timed out, start 1103936080, now 1104536091, diff 600011
SEED 41 24 6b, PIN 00 00 c7 1f 0d, KEY 06 46 9a, 118 pins/s
SEED 0d 51 52, PIN 00 00 c7 22 6e, KEY d9 e9 e5, 865 pins/s
SEED 55 3e 65, PIN 00 00 c7 25 cf, KEY 81 98 33, 865 pins/s
SEED a6 b0 18, PIN 00 00 c7 29 30, KEY 77 1d ae, 865 pins/s
SEED ad e8 4b, PIN 00 00 c7 2c 91, KEY 88 eb 6a, 865 pins/s
canMsgReceive timed out, start 4189969794, now 4190569814, diff 600020
canMsgReceive timed out, start 2896241815, now 2896841849, diff 600034
SEED 95 25 be, PIN 00 00 c7 2d 07, KEY ec d4 22, 118 pins/s
SEED d7 1c c5, PIN 00 00 c7 30 64, KEY e6 14 a2, 861 pins/s
SEED 9d 22 b1, PIN 00 00 c7 33 c1, KEY d5 57 22, 861 pins/s
SEED b4 dc 66, PIN 00 00 c7 37 1e, KEY 3c 2b 34, 861 pins/s
SEED b3 62 df, PIN 00 00 c7 3a 7c, KEY 4c 2b 96, 862 pins/s
canMsgReceive timed out, start 1687471856, now 1688071896, diff 600040
canMsgReceive timed out, start 393744005, now 394344048, diff 600043
SEED a6 20 88, PIN 00 00 c7 3a f3, KEY 0e 6a 57, 119 pins/s
SEED 9a 73 e7, PIN 00 00 c7 3e 53, KEY 42 46 3d, 864 pins/s
SEED c4 9d 57, PIN 00 00 c7 41 b4, KEY c8 40 06, 865 pins/s
SEED fb 45 b0, PIN 00 00 c7 45 15, KEY d3 71 3f, 865 pins/s
SEED 4a 6b 2f, PIN 00 00 c7 48 76, KEY e7 f7 9d, 865 pins/s
Thanks
oscilloscope
hi i have an s80 2002 euro brick style CEM , is there a way to decode the VIN from a brick style VIN ? i have a dump file , but kinda struggling with what i'm looking at
ZRimaZ
Year and Model: XC60 MY2016 3.0 T6
Has thanked: 23 times
Been thanked: 13 times
Post by ZRimaZ »
VIN is located at 0x8000+
Have a nice day,
ZRimaZ
oscilloscope
ZRimaZ wrote: 09 Jun 2022, 13:48 VIN is located at 0x8000+
thank you. , is there a way of decoding it to look like a VIN instead of ML?
