head gasket or cracked block ? 2002 v70xc
crazycat
- Year and Model: 2005 xc70
- Has thanked: 17 times
- Been thanked: 6 times
I have a misfire on startup cylinder #5. Extremely SLOW coolant loss. Exhaust gasses in the coolant verified by test. Clean oil and clean coolant. High gas pressure in coolant tank. How can I determine if it's the head gasket or cracked block? I'd hate to attempt a head gasket replacement and then still have trouble. I can do a compression test next week but I would think a bad gasket or cracked block will both show low compression. Any other way to determine what's going on? Ty
- RickHaleParker
- Been thanked: 958 times
The odds of a cracked block on a B5244T3 are pretty slim.
You description points toward a head gasket maybe some head warpage but not a cracked block or cracked head.
Mixing of oil and antifreeze in the crank case or cooling system would be a give away for a cracked block.
How does the engine run as it is now?
- Has thanked: 1502 times
- Been thanked: 3813 times
You can also carefully inspect #5 for cracks but RHP is on point here, cracked blocks are very rare in street driven Volvos
One of the R motors had an issue where the sleeves were thin but it also only cracked when teens “ I only boosted to 28 psi for a few minutes”
crazycat
RHP, after an initial 1-2 minute warm up, the rough idle misfire goes away and it runs quite well. I am chasing a ecm6805 currently, but that is only causing a drop off in power at about 3000rpm when I really get on the throttle. Thanks for all the insight about the possibility of a cracked block vs headgasket. I've been driving it for short trips <4 miles for more than a year with the slow coolant loss and gas pressure in coolant tank. I did have some kind of backfire? that blew the intercooler hose off the intercooler a few months ago, maybe that is related to the CBV not working properly and causing the overboost? I was thinking my wastegate was stuck or actuator was frozen as I can't budge the actuator arm at all by hand. Thanks again
Edit: Finally got turbo heat shield off and Wastegate was frozen shut. Actuator arm movable! Soaking the WG shaft with PB blaster now. Hopefully I’ll have proper boost back.
- 9 Replies
- 5368 Views
Last post by SvenGWK
- 1199 Views
Last post by dobrosailor
