The TPS could be causing an issue, but you will be surprised what the ABS unit does when you are not getting a clean speed signal to the ECU. I guess we will find out in due course.
Going to start with the ABS module
- Has thanked: 1839 times
- Been thanked: 1709 times
Re: Going to start with the ABS module
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
Before work Friday, I was briefly able to use the 850obd2 app to graph the voltage from the TPS and I captured an instance of the voltage suddenly spiking. There was no voltage stated, but I'm guessing it's randomly shorting. I've got a new TPS ordered and should be here Saturday sometime, and in the meantime, I'll do some more testing on the existing TPS, and try to clean it.... maybe clean the throttle body too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Oof, that's rusty! I didn't read the whole thread, but did skim it..... what finally happened with that car?abscate wrote: ↑03 Jun 2022, 04:03 Just don’t start with something too crazy…..![]()
viewtopic.php?t=95351&start=120
This V70 is not as clean underneath as my 850, but wasn't horrible. If I can get it cheap enough, I was actually thinking "winter beater", so I can save my 850 from the salt..... and it would just be cool to have a wagon.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
New Bougicord plug wires.... are tool tall??? The tops would not sit down in the plug wells, so I compared to the originals, and the new ones are about 3/8" taller! I put the old ones back on, but measuring ohms, they're not consistent.
I replaced the TPS, and while running for a few minutes in the driveway it seemed fine. I moved on to the ABS module finally, and it came out fine. HOWEVER, the insulation on the power wires absolutely disintegrated! One second they looked fine, the next second pieces! I have never seen wire insulation do that before. I guess I need to research THAT now....sigh.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Bougicord blue ones are for 10v cars.
Grey ones(like originals) are for 20v cars.
Part # are different...you should have checked original part# before ordering.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
I'll have to go look to see what color they are. I ordered them from FCP.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
I'm guessing you mean the part that reaches the plug in the plug well, not the actual wire..... wire is black. I think maybe the wires I got are mis-boxed, The FCP picture shows gray, and lists the part number I have.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- misha
Yes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
It looks like I ordered 6468, and got 6469 in the box.... so a mislabeled box.
I've already contacted FCP and they want my VIN number
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1500 times
- Been thanked: 3812 times
Might be a chassis break on these? Did you try volvopartswebstore?
