Opinions on best exhaust joint cement
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I'm piecing together an exhaust pipe link. Joints (there will be 4) will be clamped when it's finally set up. I'd like to seal them as the pieces are fit together. I think I recall some debate about the best cement to use, but I don't remember what it was—or if most people agreed on it :)
Suggestions appreciated!
Jim
Has thanked: 1611 times
Been thanked: 4073 times
Permatex makes some nice stuff for slip joints. If the hole is larger, then JB Weld extreme heat epoxy
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Personally I'd be worried about being able to separate the joints in the future if you put sealant pukkie in there during assembly.
Maybe a bit on the outside of the flange once everything is tightened down, but most "good" exhaust clamps will do the job on their own.
Just might have to retighten them after a few hot / cold cycles.
1999 V70 GLT
JimBee
Post by JimBee »
Thanks, gentlemen of the wrench for the info. Onward and upward!
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
I fought with my clamped and cemented exhaust for years. It always leaked and the clamps would rust out. The best solution I found is to have the parts welded together by a muffler shop. They'll spray the welds with rust inhibitor to make them last longer. No, you can't easily take it apart again. But, the time savings and long term trouble free operation justifies all the costs.
FireFox31
Stainless steel (304) band clamps and permeatex work great. The Starla mufflers last 3-5 years, after which a sledge hammer reduces then to return shippable size to FReeCP , courtesy of my NJ Counselor.
JimBee
Post by JimBee »
Searching on JB Weld I found this video: guy repairs a cracked BMW block with JB Weld (marine version). Looks like he drilled a hole (2 mm) at either end of the crack to limit further spreading. Repair looks neat. Will it last?
https://www.google.com/search?client=fi ... QPv5Gz4AU4
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
What exactly is JB Weld? Is it epoxy? How does it bond with oil-imbedded aluminum or cast iron?
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 115 times
Post by Goupil »
It's epoxy with metal particles in it if I remember correctly. I've not managed to find an equivalent of JB Weld on this side of the Atlantic, but I see americans praising it quite often
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Has thanked: 2210 times
Been thanked: 1852 times
JB Weld has many versions and applications from heat resistant, water proof, plastic and more. I love the stuff. Drilling a small hole either end of the crack is key to stopping the weld propagating. By having the round hole there is no point weaker than the other around the circumference. Had this done on a windshield to stop the crack elongating. Crack was just the same 5 years later!
Neil
