Going to start with the ABS module
Has thanked: 292 times
Been thanked: 765 times
Re: Going to start with the ABS module
454cid wrote: 05 Jun 2022, 12:44 .... I moved on to the ABS module finally, and it came out fine. HOWEVER, the insulation on the power wires absolutely disintegrated! One second they looked fine, the next second pieces! I have never seen wire insulation do that before. I guess I need to research THAT now....sigh.
Unfortunately this is extremely common for this piece of the harness. I just re-insulate them as well as I can.
No chassis break on the P80, 20V plug wires. I just ordered 6468 from FCP and received gray ones, though I have not installed or measured them. Sounds like mis-boxed.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1847 times
Been thanked: 1710 times
How about trying the liquid insulation repair you get for house wiring? You just dab it on with brush and it seals the insulation.
Indeed! e.g. http://volvospeed.com/vs_forum/topic/17 ... lving-sos/
Also https://midwest-abs.com/troubleshooting as a starting point for all ABS head-scratchers
'06 S60 R, 197k
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
erikv11 wrote: 07 Jun 2022, 09:27 No chassis break on the P80, 20V plug wires. I just ordered 6468 from FCP and received gray ones, though I have not installed or measured them. Sounds like mis-boxed.
From reading, I guess it's possible to pull the black plastic shroud off the motor so it's possible to reach more of the wire. I haven't had a chance to do that yet. I did get the ABS module sent off today, Though.
FCP has said I can return the wires. I'm glad to hear that you got the proper wires, that makes me feel better about trying again with them.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
454cid
Post by 454cid »
scot850 wrote: 07 Jun 2022, 10:34 How about trying the liquid insulation repair you get for house wiring? You just dab it on with brush and it seals the insulation.
I have no experience with it, but it sounds a little sloppy for doing a length of wire, and I'm not sure it would be good for an automotive environment. My plan is to use heat shrink tubing of I can get the connector off.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
That thread linked above to volvospeed has the liquid tape I was trying to explain.
454cid
Post by 454cid »
scot850 wrote: 08 Jun 2022, 10:19 That thread linked above to volvospeed has the liquid tape I was trying to explain.
Yes, I saw that after posting. My concern was actually mentioned in the thread. I have basically entirely bare wires at this point.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I understand. I think your idea is the way to go. You can also get sleeving for ground cables in houses. That may also work. You could try splitting it and then running a solder iron down the join.
Neil
I used standard tape on my 96, that was about 7 years ago. Should probably check it to see if it needs re-wrapping but it's not shorting out anywhere. All of the insulation fell off, I had the completely bare wires.
'06 S60 R, 197k
454cid
Post by 454cid »
erikv11 wrote: 09 Jun 2022, 08:40 I used standard tape on my 96, that was about 7 years ago. Should probably check it to see if it needs re-wrapping but it's not shorting out anywhere. All of the insulation fell off, I had the completely bare wires.
Good to know, if I can't get that connector de-pinned.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
