Has thanked: 1611 times
Been thanked: 4075 times
There are at least three styles I’m familiar with; the hex threaded one with a nipple, the 1/4ctwist and oring seal one, and a threaded thumb screw one.
Wait…four…the rubber stopper wired in place that I ran on my T5 for three years
Has thanked: 312 times
Been thanked: 818 times
Just finished changing front control arms and ball joints on the 07 XC70. The factory originals (180k) were still working well but the bushings all showing visible signs of fatigue. The ball joint boots were cracked but not breached, the ball joints were only slightly loose. So the post-mortem is I could have very likely let them all remain in service another 10k+ miles but I wanted to do this job when convenient for me not when they failed. Installed Lemforder control arms and ball joints. Pieced together a PVC pipe coupler to tap in the ball joint, very straightforward.
I also replaced the driver's side front wheel bearing. The passenger side went out about two weeks ago and I replaced it. I replaced the driver's side preventively because it's so easy to add on with the steering knuckle out. Installed FAG bearings. Didn't forget to install a new dust seal (Volvo brand)!
Next up replace the parking brake shoes and change the oil, then it goes back on the road.
The rubber bits on the old control arms:
LH CA 1
LH CA 1
LH CA 2
LH CA 2
LH CA 3
LH CA 3
RH CA 1
RH CA 1
RH CA 2
RH CA 2
RH CA 3
RH CA 3
RH CA 4
RH CA 4
Has thanked: 2210 times
Been thanked: 1852 times
Oooh! Those do look a bit toasty! Good bit of preventative maintenance on that.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Yep, I think I can smell the burnt toast over here.
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
I never considered buying one new w/ a junk yard so close to me. I was curious so I looked on volvopartswebstore. It had a diagram number, but nothing below in the part number section. No part number is stamped on the plug.
“Post by br0dy519 » Today, 10:59 am
Do they sell just the plug itself? I have an aftermarket (TYC) radiator and I'm always way over-cautious when removing that plug because I thought it wasn't a part you could purchase. Mind sharing a part number?”
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
Spent most of the day running errands. I'm glad my AC works, although I think it might need recharged (possibly oiled, too, to quiet the pump down).
I did look down to see the odometer was at 183200 miles.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
AC doesn't work on the S60. I put dye into it but haven't been arsed to get a hold a of a UV light to inspect. I think I'll just recharge it again.. leak check is next years problem (I'm lazy..)
04s60 2.4
04xc70 2.5t
DonnVa
Post by DonnVa »
Replaced the spark plugs, air filter and fuel filter. I piddled around a bunch on the XC and S60. I’m going to do the timing belt service as soon as the water pump arrives w/ the sealant treated bolts. Those two have been in and out of stock and I just didn’t catch them at the right time. I saw them in stock last evening and I ordered them. The XC should be pretty up to date w/ service when I complete that.
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
wch2032
Year and Model: 06 XC70
Has thanked: 11 times
Post by wch2032 »
erikv11 wrote: 14 Jun 2022, 12:12 Just finished changing front control arms and ball joints on the 07 XC70. The factory originals (180k) were still working well but the bushings all showing visible signs of fatigue. The ball joint boots were cracked but not breached, the ball joints were only slightly loose. So the post-mortem is I could have very likely let them all remain in service another 10k+ miles but I wanted to do this job when convenient for me not when they failed. Installed Lemforder control arms and ball joints. Pieced together a PVC pipe coupler to tap in the ball joint, very straightforward.
This is on my list, my control arms look a bit worse than yours. Any noticeable improvement in drive quality after the job?
06 XC70 - 251K
I also wondered if it would make a difference. After two days of usage (today is the third) including 100 highway miles I do notice improvement. The car wasn't wandering or showing obvious signs of bad control arms before, so it still drives straight etc., but it is sightly quieter and smoother for sure.
