Re: P80 Radio Head units, wiring and amp questions!
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Re: Re: P80 Radio Head units, wiring and amp questions!
Post by Goupil »
Kinda forgot about this as I was dealing with bigger volvo issues
Pictures are from a 98 C70 coupe.
Here's the head unit side
And speaker side
That seems to match BEJinFbk description, I have the grounding wire for the coupe on pin 2.
I cant exactly see where the cable is going, but I'd say it's probably around 50cm/20in long.
You can see it coming from the driver side on this picture from when I removed the dash
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Has thanked: 1843 times
Been thanked: 1710 times
Thanks Goupil this is very much appreciated.
I have one question. There appears to be 3 wires on the green connector to the rear of the radio and only 2 at the speaker end. Do you know if the black wire that is separate from the other 2 is a ground lead or where that goes to?
Many thanks,
Goupil
Post by Goupil »
The black wires disappears into the big loom behind the dash, but the multimeter says it's a ground.
You are a star! Many thanks for taking the time for this as I know you have bigger jobs on your hands! Hopefully the Volvo Gods send you the gift of your engine starting and running! :D
