There are only crickets in here...
Has thanked: 1611 times
Been thanked: 4073 times
I’ve always wanted to trade my pristine PV544 for a 1999 Sonic Blue R. Not a2000, I’ve heard too many issues
#trollscuttlesunderbridge
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
...scuttle scuttle scuttle.....
BlackBart
Post by BlackBart »
This is a fun site of old Volvo fixits, alternator conversions, broken key solutions, etc. The Swedish Embassy.
https://www.sw-em.com
Lucas Prince of Darkness.jpg (6.06 KiB) Viewed 1778 times
Chirp chirp chirp
BlackBart
Post by BlackBart »
Did I hear crickets calling for an update?
Well, this is not 122-related, but here was my fathers day progress.
Rear trailing arm bushings.
Drill them out.
Punch, grind, and tear the center sleeve out.
Cut the outer sleeve - carefully - with a hacksaw.
Chisel and bang and bash with punches - carefully - and get the damn thing to move!
Then round-file the bumps and gouges out of the insides, a little PB, some steel wool. I may need someone with a press to put the new ones in. Also got the rusted bolts out of the axle strap retainer / mount inside the rear wheelwells. Only 1 out of 4 snapped off!
BlackBart
Post by BlackBart »
Amazon content -
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
BlackBart wrote: 20 Jun 2022, 16:30 Did I hear crickets calling for an update?
Drill them out.
Well done ! Always fun to remove pressed in parts with " basic " tools. At times I've felt like I might as well be using two stones and a bone to get things apart.
Finally bought a press off of Craigs a few years ago. Have yet to use it, but my jeep might need front U-joints soon.
1999 V70 GLT
BlackBart
Post by BlackBart »
You can fix a Land Rover with a crescent wrench and a rock!
After fretting and fretting over the quality of the cheap HF press, and bad reviews about how out of square they are, I looked around for a local machine shop. They're either set up for techie stuff or water jets, or they're just not interested in onesy-twosy jobs. Gas station guy won't use his press for outside work.
So I thought, Are we not Vikings?! Lets do this right - with HAMMERS!!
After filing the bores smoother and cleaning up rust, I steel-wooled and sanded the bushing shells vertically to get them clean and smooth. Mocked up some wheel bearing plates and disks from a set I have, some wood blocks, greased it all up and mad a few taps with a 2 lb hammer to get it seated straight. It went in straight! A few solid whacks and it went right in. As the bushing came close to the other side, I switched to spaced wood blocks and tapped it flush. So slick! We don't need no STINKING presses!!
Mock-up
Go
IN !
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
BlackBart wrote: 24 Jun 2022, 16:37 You can fix a Land Rover with a crescent wrench and a rock!
Mock-up
Go
IN !
Your Viking ancestors would be proud! Brute force applied with finesse.
BlackBart
Post by BlackBart »
volvolugnut wrote: 24 Jun 2022, 16:48 Brute force applied with finesse.
Good line, I'm going to remember that!
Only, I don't think I have any Viking.......
sad panda.jpg (88.04 KiB) Viewed 1661 times
sad face.jpg (60.99 KiB) Viewed 1661 times
