Hi,
First time I ran to problems to troubleshoot my 2008 S-40i, manual transmission, 235 k, one owner. I got the code P172, replaced both O2 ,MAF, and Fuel pressure sensors, tested my vacuum brake motor apply12v heard the pump sound… opened oil cap have good vacuum. Replaced my oil breather unit and hoses 70k ago. Great appreciate for any advice…
Code P0172 Topic is solved
- RickHaleParker
- Been thanked: 980 times
ECM-250A (P0172) Long-term fuel trim. B5244S4
Condition
Engine Control Module (ECM) receives information from the heated oxygen sensor about fuel/air mixture in different load areas. If Engine Control Module (ECM) registers that fuel/air mixture deviates too much from target lambda, so that adaptations end up in any of its end-positions, the diagnostic trouble code is generated.
Substitute value
None.
Possible source
Upper limit
Condition
Substitute value
None.
Possible source
Upper limit
- Incorrectly installed oil dipstick. Air leakage.
Too high ethanol content in fuel.
Air leakage in the intake system.
Air leakage in the exhaust system.
Low fuel pressure.
Damaged mass air flow (MAF) sensor.
Damaged, dirty oil trap.
Clogged air filter.
Dirty mass air flow sensor.
- Oil level too high.
Contaminated engine oil.
Leaking injectors.
Damaged evaporative emission system (EVAP) valve.
High fuel pressure.
Clogged air filter.
Active
Past
Past
- 10 Replies
- 3016 Views
Last post by charleskennedy23
- 5801 Views
Last post by matthew1
- 977 Views
Last post by pgill
- 1583 Views
Last post by xyourobob
- 540 Views
Last post by flat_tomato
