Going to start with the ABS module
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Well, it seems there is no depinning that connector. Once I got the outer plastic off, the inner is molded rubber, so I can't split the wires without cutting. Cutting the rubber might be okay if the outer housing would keep it all together. I'll have to look at it closer. Otherwise, I think I'll try the liquid "tape". I've looked at a few videos of people using it, and it looks like some neat stuff.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2215 times
- Been thanked: 1853 times
It may not be pretty but it does what you need it for and you can't really see it to worry about aesthetics. With a bit of practice and thin layers it may end up being a work of art!
454cid
Yes, I was thinking of layers, but given what I saw on Youtube, it looks pretty thick. I guess I'll have to see what the particular brand I bought is like to work with.scot850 wrote: 12 Jun 2022, 15:31 It may not be pretty but it does what you need it for and you can't really see it to worry about aesthetics. With a bit of practice and thin layers it may end up being a work of art!
I'm thinking I may also use tape on top of the liquid stuff. I've also kicked around the idea of cutting the connector off, and asking Mattymoo to leave me power wires hanging out of the module for me to do something with. I have not run the idea past him, Though. At that point, I may be overthinking it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
454cid
That's just the outer case. The wires are still both held together with rubber, so I can't slide heat shrink tubing over each wire to insulate them.850oldschool wrote: 18 Jun 2022, 12:12 The connector on my 96 was very easy to depin, just a matter of removing the retaining clip. Is yours different?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
850oldschool
OK, so you've got the hard plastic part off? Typically with a little flexing and rolling the wires between your fingers the deteriorated rubber will just fall away.
454cid
That part isn't deteriorated, only what was directly on the wires. I'm not sure the pins would even stay in the plastic, if the rubber was gone. Did you have completely bare pins on yours?850oldschool wrote: 18 Jun 2022, 13:45 OK, so you've got the hard plastic part off? Typically with a little flexing and rolling the wires between your fingers the deteriorated rubber will just fall away.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
850oldschool
The rubber insulation completely disintegrated in my hands. There was residue left in the terminal shell which had to be dug out with a small screwdriver.
The rubber insulation seemed to play a part in centering the terminals and also the retaining clip in the connector needs something large and soft to bite into, so I added a precise wrap of self fusing rubber electrical tape. Getting this the right size took several attempts.
454cid
Ok, well, I think I've got this wrapped up finally. I don't really like I how I did the wires, but it appears to work. I coated the wires with liquid tape, then linearly folded a piece of rubber electrical tape over each wire and then folded again, and then finished it up with regular vinyl tape. I had to cut a slit in the plastic cap that goes over the motor, to get it off, so after putting that back on, I put a piece of vinyl electrical tape over the cut.
I did the former last night, but ran out of light. I got up early this morning and put everything else back together, except one piece....
How is the tab held to the battery tray that captures the positive battery cable? I removed some kind of fastener, but am not finding it. Did it have a nut on the back side of the tray, or does it thread into the plastic? It actully looks like it's designed for a u-clip.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
It should have a 'U' clip. I can't recall if it has a nut on the back or it is already threaded. Look at the 4th picture on this link.
viewtopic.php?t=29930
- 11 Replies
- 7399 Views
Last post by Vovoroom
- 10 Replies
- 6158 Views
Last post by misha
- 1652 Views
Last post by Dzikiewicz
- 537 Views
- 2299 Views
Last post by yagger
