jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
spent all afternoon fighting with the front muffler to cat flange, still getting a small exh leak at the bottom of the flange.
So I removed everything again.
I ground the mating surfaces flat and shiny, new gasket.
Better but still a slight pfft.
Whats next, exh cement?
Looking at the photo I think I assembled one of the clamps wrong, its pulling apart.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
Where's the flex pipe? I don't think you'll keep it from pulling apart without one, unless you do all solid engine and trans mounts to keep the engine from moving even the slightest bit.
Has thanked: 1614 times
Been thanked: 4078 times
Cut those flanges off amd bridge the pipes with a band clamp, the only thing cooler than oetiker clamps
jonesg
Post by jonesg »
gnalan wrote: 21 Jun 2022, 18:17 Where's the flex pipe? I don't think you'll keep it from pulling apart without one, unless you do all solid engine and trans mounts to keep the engine from moving even the slightest bit.
flex pipe is before the cat,
this joint is after the cat.
jonesg
Post by jonesg »
using a new gasket, slathered with exh cement, it sealed up nicely.
now to bleed the bleeding brakes....and maybe an oil change.
jonesg
Post by jonesg »
has anyone tried the airbag jack, $150 on amazon.
Garage is a bit cramped to use the regular trolley jack, not enough room for the long jack handle on both sides.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
pop....fsssssssssssss.....OW!!
But seriously, it looks kind of jumpy and not controlled. You can't get a floor jack straight in the from the back? Or in my tight garage, sometimes I put the jack more parallel to the car - at an angle reaching under. Then the handle swings down close to the doors and doesn't hit the wall.
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
I replaced the rubber drip trim and cowl pieces on both sides this evening. Looking good. 😀
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
jonesg
Post by jonesg »
BlackBart wrote: 23 Jun 2022, 16:22 pop....fsssssssssssss.....OW!!
jumpy because its air, not hydraulic.
I couldn't think of a more stupid place to put the jack than balance it like that,
DonnVa
Post by DonnVa »
Flushed my transmission fluid in my XC, which I now call my truck. 😬 It was confusing leading up to the flush as I checked it several times while it was hot and the fluid was way above the full line. When I drained it earlier, I got 5qts + 2.76ozs. It should have been around 3.5-4qts. I made note of the overage and put 3.5 qts in it and did two flush cycles to bright red. I drove it around the block going through the shifts and checked it. It was at the full mark, not over. I’m going to take the fluid to the recycling center which should get it nice and hot and check it. If it’s over full I’ll pull 200ml out of the dipstick tube w/ the syringe. The difference between the cold and hot mark is supposed to be 200ml. Note: According the the vehicle carfax the transmission was flushed at a trans shop at 120k miles.
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
