Cruising at 50 mph, sudde gulp , and CEL on
Pulled over and checked code, P0237
I drove home about 35 miles. With code cleared, no gulps. About 10 miles from home, gulp CEL
once CEL is back, gulps return every 20-15 minutes under boost demand.
Searched forum for P0237
search.php?keywords=P0237&fid%5B0%5D=1
ECM-1600 is intermittent failure of signal to boost pressure sensor
Vida reports once this code sets turbo boost control is open loop. Hopefully that explains the gulps of power
Will inspect wiring and possibly sensor and report back
1999 v70t5m56 Elizabeth p0237 code 9125462 Topic is solved
Inspected MAP pressure sensor. Slight corrosion on terminals replaced with spare
Problem resolved , pending pribabtion of 2x month/1000 mile test
Cleanest fault…code…part…solution I’ve had a a while!
Expensive part, $112 at web store
Bosch 0261230029 map,sensor
B006K8ZKT6
Sensor 7/81 in VIDA
B006K8ZKT6
Sensor 7/81 in VIDA
- Has thanked: 2198 times
- Been thanked: 1851 times
Glad it was that simple!
Repair validated with a four hour grind down the Taconic, then through NYC without any codes or problems
- 21 Replies
- 5904 Views
- 303 Replies
- 37230 Views
Last post by bmdubya1198
- 41 Replies
- 10557 Views
Last post by EngineeringBloke
- 28 Replies
- 5724 Views
- 12 Replies
- 1470 Views
