br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Yeah I’m very familiar since I replaced wifes xc70 3x last year with a crappy rebuild and Chinese regulator. Ended up getting a brand new Bosch one that my mechanic had on the shelf. I’ll be seeking a Bosch branded regulator in the rebuild for my car.
Today at the gas station after fueling the XC it wouldn’t start for a few times. Cranking very strongly but just not firing up. It finally sputtered alive weakly and came fully alive after giving some gas. Couldn’t reproduce it again today. Going to see if anything threw a code…
04s60 2.4
04xc70 2.5t
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
abscate wrote: 30 Jun 2022, 02:38 Best to haul it off and take it to a local auto electric shop for a $100 rebuild vs the crappy rebuilt ones in the supply chain now
But you can't rebuild alternator for $100. Quality bearings, pulley, slip rings, rectifier, voltage regulator are way over $100 just in parts. I wouldn't be even looking at sub-$300 rebuilt alternator.
Or are you talking about replacing the voltage regulator only? For P2 in 2022 it would make sense to rebuild alternator properly. I regret I was cheap a few years ago and didn't replace the rectifier. Now the car is asking to pull the alternator again.
Has thanked: 311 times
Been thanked: 817 times
Drove it 1003.7 miles on Tuesday.
Average 71 mph and 25.9 mpg for the trip.
br0dy519
Post by br0dy519 »
vtl wrote: 30 Jun 2022, 08:34
This is why I don’t understand the huge influx of new threads asking about just replacing the regulator. There are so many other components that can fail in the alt. Why throw $100 at it with a regulator when something else is guaranteed to fail soon after? Doing the job twice sucks and is expensive. /rant
I fully realize how ironic my post is considering how many cheap aftermarket parts i’ve thrown at my cars. But like you note, the alternator is a no-brainer to go quality on. All of my chinese regs failed within 24hours.
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I think my regulator from FCP was bosch, $48.
BlackBart
Has thanked: 967 times
Been thanked: 922 times
Post by BlackBart »
erikv11 wrote: 30 Jun 2022, 08:38 Drove it 1003.7 miles on Tuesday.
That's a drive!
jonesg
Post by jonesg »
so I finally sealed the leak at the cat to resonator flange. The flange bolt holes were rotted away.
, I put a split coupler on each side of the joint,
a 3 inch section of 63mm pipe inserted (hammered) in the cat side,
resonator side is slightly bigger , the flange bolts drew it together.
vtl
Post by vtl »
Very much doubt for how long this fix will work, without good 4-5 layers of duct tape!
DonnVa
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
I replaced the rear stabilizer links on the XC. I was going to do the Haldex filter and fluid exchange today, but that just turned out to be fluid. I didn’t feel comfortable with my ability to get the top 4mm screw back in and tightened on the filter cover w/ that spring pushing out against it. It’s a real tight space even with my little Chapman ratcheting tool. I did suck out about 200ml of fluid out of the fill hole. The fluid I extracted looked pretty good. It was darker than the new fluid, but still translucent. I just put approx. 200ml of new fluid back in and called it a day. The XC is running and driving real nice. I’m going to get my S60 ready to sell in the next week or two. Basically I need to stop procrastinating and take some pictures. I’m not looking forward to the Craigslist experience. 🙄
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
Been thanked: 4071 times
Don’t forget to list it here first and on Swede speed
