P80 AWD rear panhard suspension rod stay and hardware 9200005 and 9157297
Been thanked: 4068 times
Thread to discuss these guys found on AWD, XC70, R models,
The stays fit on either side with the nylon bushing inboard
If your look like this they need replacement
Documenting that the nylon bushing end goes into inside of the suspension- this makes sense as the hard end of the wheel spindle should be rigid, and the movement inboard is thus smaller and less wear.
There appear to be two part numbers. Little confusing text on the application
9157297 AWD except XC
9200005 for XC
Outboard attaches with a M12x 25 flange bolt, 17 mmhexhed
There is a large flat custom washer on this, from Tasca or Volvo only
Bolt 985053 or 949708
Washer 986396
Inboard is the adjustable toe in consisting of a long slotted eccentric bolt, a internal toothwasher, and a lock bolt
The bolt inserts from front, you have to turn the eccentric to clear the differential
The factory bolt uses a fancy hex boss at the top of the bolt with an internal hex washer that fits inthe boss.
The replacement bolt has the eccentric cast as one piece
Bolt 986933 …..this shows as NLA at Tasca….uh oh
Washer…
Nut. 985870 at Tasca
Tightening torques
Has thanked: 2203 times
Been thanked: 1852 times
That will have to wait for later busy day today (hoist is being installed!!) and it will take some time to find it if I have it (I should have).
Do you need the rod? I may have a couple of spares.
I will need to look at the bolt as I may have that too somewhere...................! Do you know the spec of the bolt?
I have the rods (still available) and the bolts - but it looks like anyone else moving forward is out of luck
Yikes! Looks like more reason not to have an AWD! :(
You can see I broke one removing it, a $25 dollar mistake. When I go to do the right side on this car, I will cut the nut off with a Dremel to
Preserve the NLA BOLT.
Both nuts and the slotted washers are still available and used in P2s so those should be around for a while.
Bolt fab idea. A M12x 100 bolt, then Dremel a channel length wise to receive two slotted washers. Chase threads. Tack weld head washer to shank or bolt head
Bump to document
Nylon bushing inboard
Metal bushing outboard.
Still available from FCP or Skandix
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Sadly the stay is no longer available from FCP, only from Skandix.
https://www.fcpeuro.com/products/volvo- ... 70-9200005
