engine oil
can
Year and Model: 2000 s70 2.0 t5
Has thanked: 23 times
engine oil
Post by can »
Hi.
My car
S70 t5 Aut 2000 model 190450 mil
What are your engine oil recommendations?
thanks everyone. :D
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
can wrote: 08 Jul 2022, 11:32 Hi.
My car
thanks everyone. :D
I use part synthetic but the other guys here probably know better.
I have read that synthetic might bother the seals on engines that were made for regular oil but it could be a myth.
If in doubt, use regular oil and just change when you are supposed to and should be ok.
I used part synth because that's all they had when i went for my last oil change.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
I'm running Shell Rotella T6 5w40, which is a full synthetic. It's what I used on my first oil change in this car. I need to change the oil again, and I'll likely use the same.
Edit: My car is not a turbo.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
^ That's hard to find right now, at least in my neck of the woods....
1999 V70 GLT
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
MrAl wrote: 08 Jul 2022, 13:10
My car
thanks everyone. :D
Leaky seals from synthetic oil is not a myth. It only applies to 100% synthetic oil. That is not available at Wal-Mart or Discount Auto or any Jiffy Lube. In fact not even the Volvo Dealership uses it. In America full synthetic is Group 3 oil made from crude oil since 1999. I discovered this on MVS when my car had 140K. I switched to a true synthetic group 5 oil named Redline 5w30 and within 15K the rear main and cam seals which were original blew at different times pouring oil out then another 20K the O rings in the vvt hubs blew. So old round seals made of rubber like material leaked along with rubber oil lines to turbos over a 40K period of mileage after switching from Group 3 to 5. My car had 3K or 3 months whichever came first Dealership synthetic oil changes from new to 140k. The bonded seals like oil pan and cam cover are fine still original. My car has been in service since 12/2003 and has 215K. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
454cid
Post by 454cid »
Sveedy wrote: 08 Jul 2022, 17:55 ^ That's hard to find right now, at least in my neck of the woods....
Yes, since I bought the first batch, of T6, I noticed it didn't seem to get restocked. Finally, it started getting restocked before quickly selling out. I actually bought another oil first, but then was able to grab a couple of jugs of Rotella since then.
When I noticed it being in short supply, I googled it, and found it's a problem with the supplier of the additive package.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Doesn’t it say in your book for the car what oil you should use?
I always run fully synthetic in every car we have.
BMW 540i 2002
S70 Base 2000
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Been running full synthetic 5w40 liquimoly for a few years now. No leaks, no issues, engine has 215,000 miles. Did the same for my xc90.
can
Post by can »
full synthetic 5w50 .
full synthetic 10w60
Is it ok to use these oils?
air temperatures in my area;
winter: max -10 centigrade
summer: max +35 centigrade
If we consider the engine wear for a vehicle with this shaft, I think that the viscosity of the engine oil used should be higher.
There are folks with more experience in this field.
454cid
Post by 454cid »
can wrote: 09 Jul 2022, 17:04 full synthetic 5w50 .
Seems awfully heavy to me. Those aren't oils I've ever seen in the US.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
