Fix a Volvo flip/switchblade key - DIY, pics and advice
This topic is in the MVS Volvo Repair Database » Fix your Volvo key flip /switchblade key - pics and advice
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Song, do you still have the photos for this switchblade key fix?
For instance, the first two in that post are:
Code: Select all
[img]https://thehuangs.com/images/Keyfob1.jpg[/img]
[img]https://thehuangs.com/images/Keyfob2.jpg[/img]
Also -> Amazon link
Phixion
Year and Model: 2004 S60 2.5T
Has thanked: 2 times
Post by Phixion »
ZionXIX wrote: 14 Jul 2022, 21:42 It takes a lot of time and patience. Once the halves are separated you will see how plastic is holding into the capsule. I took a sharp box cutter a scraped away plastic once layer at a time. It took hours. Always cut away from the capsule, not towards. Just incase you slip. There was minimal to no epoxy in mine.
Awesome, thank you!
Been thanked: 504 times
Post by cn90 »
After reading this thread for my 2006 S60 Flip Key...
Too much work to cut into 2 halves, and fix it for ~ $30...
I decided to fix it the "ghetto" way.
All you need is some "door rubber cushion, the soft type".
You can find at any hardware store.
This is the stuff you put on door frame so when you close the door at home, it is quiet.
Cut a small piece and wedge it as shown.
To open the key, simply use your finger nail to take it out of the closed position...
Not a perfect fix but it works for me...
