I’m bad at screw clamps. Anybody use Oetiker clamps?
Been thanked: 4071 times
kallekula wrote: 15 Jul 2022, 11:55 Isn’t the thing with oetikers that they adjust to the crimping aging hose it’s clamping onto. Oetikers is like a “spring” sort of. Leaks develop later than traditional screw clamps.
It’s that and the consistency of assembly that make them the choice on new cars
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
They’re much faster to fasten compared to a screw clamp.
BMW 540i 2002
S70 Base 2000
And much faster to remove, too.
Zip zip zip
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
How do you easily remove an Oetiker clamp? I have to fight them with a flat head screwdriver. The results aren't pretty.
FireFox31
Dr Dremel
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Great in assembly settings, like a factory.
Not so great in everyday real world settings. And not re-usable. Might as well use a zip-tie.
1999 V70 GLT
kallekula
Post by kallekula »
FireFox31 wrote: 15 Jul 2022, 14:28 How do you easily remove an Oetiker clamp? I have to fight them with a flat head screwdriver. The results aren't pretty.
There are a few tricks. Checkout youtubes.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Zip ties get brittle with time (and heat).Do it right from the beginning and there will be no reason to revisit the problem again…
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
My name is Dremel, Dr. D Dremel 😂
BMW 540i 2002
S70 Base 2000
Dr Dremel is not going to fuss with stripped clamp heads and ugly clamps , no mo’
I didn’t even bring the screwdriver underneath when I saw that
Also, $450 in labor saved from dealer…
