Yet another ABS Problem
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
:evil: Yet another abs problem . Ive been searching the interwebs but most i find is the BCM solder repair of the bcm which was done (by nocansolder me years ago).
However, there are no ETM, ETS etc lights on.
I believe the problem is internal to the “brake distributor block”. Funny thing is I think I can pin point when it happened (years ago) : i slammed the brakes to avoid an accident. When doing this I could almost feel in the foot that something gave at the same time as the brake pedal slowly was pressed down into the floor. I can testrun the pump motor which sounds horrible and is probably in need of some lube. Brakes are just bad. Car starts rolling in traffic from stand still etc. Bad weak brakes. I recently replaced the brake master cylinder but no cigar.
So, is it possible to only replace the block with the exact productnr as mine or can I pick anyone as long as those magneto pins matches the BCM?
Thank you for looking.
BMW 540i 2002
S70 Base 2000
Has thanked: 1611 times
Been thanked: 4072 times
I’ve got a 2000 block and motor off Jane I can send you. Pm me shipping or I’m out west in a few weeks
I don’t like the diagnosis though, unless you can see brake fluid in the block or leaking ??
kallekula
Post by kallekula »
abscate wrote: 17 Jul 2022, 05:15 I’ve got a 2000 block and motor off Jane I can send you. Pm me shipping or I’m out west in a few weeks
it doesn’t leak a drop. It must be that big aluminum block. Quiestion is if all the numbers on the new block matches the old one.
BMW 540i 2002
S70 Base 2000
It’s a 1999 2000 part only. It is the first yearwith independent rear braking, right and left
You guys inthe OC might not feel the ABS that often on dry pavement. You will feel funny broken stuff in your foot when it activates
If the pedal is loose, flush all the calipers and look for air first, before you tear into to big block
kallekula
Post by kallekula »
Pedal doesn’t sink, I vacuum tested booster, new master cylinder.
Back to the question, must the product number of the “blocks” match? Just like the BCM numbers must match if you have dstc or something else??
EDIT: I remember someone mentioned brake hoses could break down internally and may cause a “stop” in the line? Not sure about it because when I looked at this brake problem a while ago all lines flushed fine.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
There are no leaks
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
PM me so we don’t have to deal with freight. Ill double check the numbers. Im not far from LB
BMW 540i 2002
S70 Base 2000
Digging into this, there are three components here but it doesn’t look like all three are orderable from Volvo
Black cylindrical PUMP motor, provides into for pump
Aluminum BLOCK containing valves and centrifugal pump
Black plastic ABS module...mattymoo is the go to for this repair or replace
I ***** think ***** only the module requires matching no/TRACS/ STC
I have taken the pump off a block and swapped, putting the pump back in is a bit of pig but doable.
Pictures from volvoparts we store below, annotated.
