I can.
PM me .bin and your wishes.
Yes, this is absolutely correct, but not everybody has a teensy here and if we can simplify things in use why not.So, this is how others cracking P2 CEMs. We went above and beyond, and came up with a novel cracking method that also works on P1![]()
Agreed with everything said, but the whole journey came to life because a few minds got bored =) I regret nothing.T5Luke wrote: ↑19 Jul 2022, 16:24 Yes, this is absolutely correct, but not everybody has a teensy here and if we can simplify things in use why not.
We also have seen many have probs to get everything running correctly, and if it is possible to offer a simply solution why not.
Many users have a dice here and got the installiation running. A simple click and the code is found in max 32h on this p2 models. Yes teensy can do it in less than 30mins but ordering a teensy plus components and figure out how everything works takes over 32h ,till the first package arrives mostly 32h are still over...
On private car you won't use the teensy again but dice gives you very nice dtc presents for a long...
If you brave enough to read through the thread, I've attempted to do that. But Volvo hired either a bad programmer or a brilliant one, and their pin compare code is not vulnerable to timing attack
