Vida CEM swapping
yamaha1024
Year and Model: xc60
Post by yamaha1024 »
I want to know if PIN
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
5 bytes/10 nibbles on P3, in HEX.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
UDS just needs a correct seed/key pair, and will give 65,536 pins. Any will work. Algo, and python script should be here in the thread, or over on the other site.
vtl
Post by vtl »
gnalan wrote: 20 Jul 2022, 10:54 UDS just needs a correct seed/key pair, and will give 45,536 pins.
Curious, why 45536? Or is it BCD pins? For HEX it gives 65536 collisions.
gnalan
Post by gnalan »
It's 65536. The 4 was a typo.
attackT800
Year and Model: S90
Post by attackT800 »
I can
jaywats
Year and Model: 05/06 s60r
Has thanked: 14 times
Post by jaywats »
T5Luke wrote: 16 Jul 2022, 16:11 Who still searches his pincode and has a P2 car from model year 2006-
Just a DICE-206751 is enough to crack pin and dump full flash without any risk.
(or 2005- CEM with series number starting by 0000491...)
@t5luke I have a MY2006 s60 will verify the serial/series. Are you able to write to cem as well? Can you share software? Thanks
P2 - 06 S60 2.5 || 05 S60 2.5 || 02 S60 2.3
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
At the moment i give hints to get the code by pm or someone else uploads it here, i won't do that...
vtl
Post by vtl »
T5Luke wrote: 21 Jul 2022, 13:45 At the moment i give hints to get the code by pm or someone else uploads it here, i won't do that...
C'mon, opensource it! ;) I'm so lazy that I'll never write a CEM flasher for my needs, even that I know most of everything that is needed for the task (90% of which is thanks to you).
T5Luke
Post by T5Luke »
I won't make any secret about it, the code is here in forum already. Take the standard routine and bruteforce with this. You can log the commands or i can write the p2 commands here no prob. When i get my code clean and checked every dependency i would do this. But don't forget we have different rights here and so on, also our country is one with the biggest car industry. Rights are more friendly to industry here. A company like the one in Czech couldn't exist here... I already heard about people in Sweden got threatened from cz just by logging soft... :D
Maybe i find the free time to do it here as open...
I can also post bootloader to dump cem, maybe it has use for teensy project...
