2006 Volvo V70 FWD transmission not working at all, no codes
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
The transmission is not working at all. I have the front end raised/front wheel off the ground. Transmission indicator is working, shift cable attached, but no forward or rearward tire rotation when put in D or R. Geartronic / manual shifting no result either. Scanned the car with Vida and no codes.
Does anyone have an idea what to check next?
Current milage 185k but the transmission was replaced by Volvo under warranty at 100k by the previous owner.
The transmission developed a shift flare with 3-4 shift since the last 3 weeks, did a drain and fill and added some lubequard, did not help. It has an external atf cooler and magnafine filter.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Are both axles still firmly engaged?
Rvolvos
Post by Rvolvos »
Yes and the differential is working too.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Do you have a whining sound? How long did the “flaring” go on? Might be you smoked that clutch pack and pump is beginning to whine because the filter got clogged. Sounds bad, like a brokrn hard part
BMW 540i 2002
S70 Base 2000
Been thanked: 504 times
Post by cn90 »
And ATF fluid level is ___?
jking4020
Year and Model: 1997 850, 2001 v70xc
Been thanked: 3 times
Post by jking4020 »
If it went out after the extra chemicals you put in id do a complete drain and fill. Then another and maybe another. Not all additives are good for our cars. Change filter of course. Does it feel like its going into gear but still does nothing?
Rvolvos
Post by Rvolvos »
kallekula wrote: 23 Jul 2022, 14:23 Do you have a whining sound? How long did the “flaring” go on? Might be you smoked that clutch pack and pump is beginning to whine because the filter got clogged. Sounds bad, like a brokrn hard part
Flaring, 1 or 2 months, no whining sound at all.
I agree with a broken part, because it is doing nothing at all
2006 XC70 2.5T 238k
2012 S60T6 95k rip
Rvolvos
Post by Rvolvos »
cn90 wrote: 23 Jul 2022, 16:20 And ATF fluid level is ___?
I checked it after the drain and fill 3 weeks ago with the atf at 80 degrees C, spot on.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
Rvolvos
Post by Rvolvos »
jking4020 wrote: 23 Jul 2022, 16:21 If it went out after the extra chemicals you put in id do a complete drain and fill. Then another and maybe another. Not all additives are good for our cars. Change filter of course. Does it feel like its going into gear but still does nothing?
Used Lubequard because it was recommended by other users. It is worth a try, but If that would be the case, I would at least expect the tires to turn when off the ground, without a load.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
kallekula
Post by kallekula »
Time for a transmission overhaul project!
BMW 540i 2002
S70 Base 2000
