Car stalling when in gear and under load
Maybe had bad gas
Put in 35 dollars of super unleaded
Along with
Injector cleaner
Seafoam
Stop fuel treatment
Blah blah
Trying to flush out the bad gas. If that's even it. Lol
Car has 250k miles
New timing belt 2k miles ago
Car will run 65 mph but have to feather the gas to make that happen.
When it sits overnight and I started cold I can punch it and it does whatever I want with full acceleration.
But after she warns up starts getting finicky!
My thoughts are...
Fuel filter
Vac line leak. (search with WD 40)
Spark seems ok ... Because when it stalls I do smell gas everywhere LOL
Anyone have any thoughts or suggestions? I honestly don't know where to start.
Oh! I did clean the battery terminals and pulled the spark plug wires and reattach them.
Help?
Al
1998 v70 GLT
- Has thanked: 2210 times
Just had similar issue with a 97 850 GLT (LPT). It was the fuel pump relay. Other issue may be the MAF. If it starts playing up, try disconnecting the MAF and see if the issue goes away.
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
I have a new MAF (from a junkyard) and I have disconnected it, no difference in runnability.
How would the fuel pump have a part of it?
Because it does run up to about 4k 5k rpm in neutral and about 70 mph 2600 rpm, but faster than that and it stumble and won't take any more throttle, and then drops rpm back to the basement.
Thoughts?
Al
Thoughts?
Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
- Has thanked: 1611 times
- Been thanked: 4075 times
What’s the history on cap, rotor, wires, and plugs?
surfbug1
Just tried to spray wd40 on some vac hoses. No change.
Also, I have a new tcv turbo control valve...maybe I can throw that in there this weekend.
When it's cold it runs fun up to about 4000 rpms
But, even cold, if you punch it, it will run ok, then stumble.
I will have to do some more scientific ( run it up and down the 1/2 mile strip out back) tests and then take notes.
Thanks!
Al
Thanks!
Al
Ping me!
Ping me!
surfbug1
Plugs are new in last 5 k miles
Wires...are they date stamped? I can check
Cap and rotor, I don't know, so may be a while.
Best to get the Bosch factory for that stuff?
Order online or local parts store my not bend me over toooo far lol
Good idea to eliminate this stuff , so thanks
Al
Ping me!
Ping me!
Fuel suggestion was because you said it was stalling under load. Relay warms up and then becomes intermittent and stumbles or dies under load. Your junkyard MAF could be bad too, but disconnecting it as you have done should have made a difference if that was it.
Have you checked fuel pressure at the fuel rail. Should be around 43psi for your car.
Check your Turbo intercooler pipes for splits or being loose.
There is a diaphragm in the turbo waste gate that also fails.
Cam/crank position sensors?
Like abscate suggested if age/condition of parts are not known then a service may be worth while. Are you getting any engine check lights or codes?
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Bad coolant temperature sensor?surfbug1 wrote: 28 Jul 2022, 17:14
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
surfbug1
Would that cause a stumble ...no acceleration under load, .....but engine will spin to 5k rpm in neutral.
Thanks, I can change it to make sure and eliminate it as well
The fuel pump relay sounds reasonable
How much are they?
Ping me!
Ping me!
- 17 Replies
- 3244 Views
Last post by skloon
- 11 Replies
- 3900 Views
Last post by dwhite66
- 979 Views
Last post by shadetree_v70
- 445 Views
Last post by Ben850
- 766 Views
Last post by misha
