2005 XC70, 186000km
I bought the car about 20000km ago, and went to swap the spark plugs for the first time. Nos.1, 2, 3 and 5 were routine. But No.4 is completely round, and I can't get a socket on it. I don't mean the flats are damaged and rounded - it looks like there never were any! Just a dark metal ring. Never seen anything like it.
Any ideas out there why there's such a spark plug? And how to get it out?
Thanks
Completely round spark plug. Why? How can I get it out? Topic is solved
You will need a extractor with fluted edges like those made by Irwin or others. That should work.
If not, the head will have to come off, ugh.
- Has thanked: 311 times
- Been thanked: 817 times
Let's see a pic when (fingers crossed)! you get it out. Must actually be stripped right?
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
I don't think you have as bad of a problem as a rounded off spark plug. I used Photoshop to lighten your photo and it looks like the rubber spark plug boot broke off and is still in the spark plug hole. If you dig this out you should be able to get your socket on the plug.
Nice work firstv70volvo!!!firstv70volvo wrote: 29 Jul 2022, 09:18 I don't think you have as bad of a problem as a rounded off spark plug. I used Photoshop to lighten your photo and it looks like the rubber spark plug boot broke off and is still in the spark plug hole. If you dig this out you should be able to get your socket on the plug.
myzomela
- Year and Model: V70XC MY01; S40 MY98
Thanks - this was it! The rubber / plastic boot had got really hard and was stuck on very well. That tricked me into thinking it was part of the spark plug. But eventually i managed to work it loose and get it out. You'll see in this photo of the old plug that you could hardly design a better "cover" for the flats.firstv70volvo wrote: 29 Jul 2022, 09:18 I don't think you have as bad of a problem as a rounded off spark plug. I used Photoshop to lighten your photo and it looks like the rubber spark plug boot broke off and is still in the spark plug hole. If you dig this out you should be able to get your socket on the plug.
I've now got 5 new Bosch plugs in. I wonder if Bosch has found a new spark plug factory yet...
- Has thanked: 2856 times
- Been thanked: 1332 times
Whew. I thought for a second the previous owner had installed one of those special round ÜRO spark plugs!
myzomela
There's a pic in my reply to firstv70volvo. Not stripped, thank goodness!erikv11 wrote: 29 Jul 2022, 08:16 Let's see a pic when (fingers crossed)! you get it out. Must actually be stripped right?
- 3020 Views
Last post by Roger_850T
- 1019 Views
Last post by ashlee2319
- 16 Replies
- 3406 Views
Last post by RickHaleParker
- 660 Views
Last post by sanfelice
- 3884 Views
