I'm going to flush the brake fluid on my 2002 and 2008 S60s. 2008 seems to be braking better with a double pump currently.
Will one quart/liter be enough for each car to fully flush the system?
Curious how much you all have used so I'm not short as it looks to be a higher end DOT4+ needed.
S60 Brake Fluid Flush: How Much Fluid?
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
250 ml per wheel is my benchmark for refreshing. I have a marked glass jar for that.
Don’t forget to return your liter of DOT4 for refund
- Krons
I do return it, but to my local hazardous waste dropoff. I am glad they have seals on those bottle for those that do "return" it!abscate wrote: 18 Jul 2022, 02:14 250 ml per wheel is my benchmark for refreshing. I have a marked glass jar for that.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Krons
Flush complete yesterday. Wow that fluid was a olive green nasty mess. Is took just under a liter to complete.
I used a $31 Harbor Freight bleeder that hooks to your air compressor. My compressor was a little small to keep 100psi continuous pressure to pull the vacuum to suck out of the caliper so had to help by pumping the pedal but still helped to make a one person job.
Only piece I missed was how to flush the ABS unit. I did go to a nearby gravel road to actuate the ABS a few times, not sure that'll help anything.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Been thanked: 504 times
You have it up to 100 psi and the reservoir did not blow up?
I made my own ATE brake bleeder cap and use only 10-15 psi (photos and info in S80 forum)...
- Has thanked: 311 times
- Been thanked: 817 times
Thanks Krons for the post I have been wondering about this tool.
https://www.harborfreight.com/brake-flu ... 92924.html
These pneumatic bleeders are set up from the other side, they use the air compressor to create vacuum on the caliper side. Therefore the master cylinder side is not pressurized. It's a cheap ($32) and tidy solution. I have not tried it but I am interested.cn90 wrote: 31 Jul 2022, 07:57 You have it up to 100 psi and the reservoir did not blow up?
- Krons
Erik hit it, uses 100psi at the tool on the caliper to create vacuum suck the fluid out. Not pressurize the cap. I'd still buy again as it was easy to pump brakes and check when the hose had clear fluid in it.cn90 wrote: 31 Jul 2022, 07:57 You have it up to 100 psi and the reservoir did not blow up?
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
The ATE Brake Bleeing cap is in this thread.
Cost is $10.
Nothing to clean when all done...
DIY: 1-man Hydraulic Bleeding Kit using Air Compressor!
viewtopic.php?t=29243
Cost is $10.
- Krons
Maybe for bleeding that process works well but for a full flush I'd rather pull the fluid via the calipers to ease topping off the reservoir throughout the process. Either way gets the job done.cn90 wrote: 31 Jul 2022, 17:09 The ATE Brake Bleeing cap is in this thread.
Cost is $10.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 10 Replies
- 1223 Views
Last post by hausmeister
- 1618 Views
Last post by moonweasel
- 18 Replies
- 10969 Views
Last post by erikv11
- 2877 Views
- 1646 Views
Last post by MoVolvos
