Temperature gauge low
vidalgerhold
- Year and Model: 2002
Normally it's just slightly over the 1/;2 mark but today, (after our first cold night last night if that means anything) it's the dashboard gauge is low, maybe 1/3rd of the way up. It did rise a bit after 20 minutes or so but still not what it always is. Is that a bad thermostat maybe? -- thank you
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I would suspect a bad thermostat sticking open a bit. Mine was that way when I bought it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Try unplugging and replugging the connector to the coolant sensor first, it's an easy first step in case the contacts are cheesy, at least on the -'00 cars. If you go for the thermostat, use caution on those torx fasteners; pre-treat with the fluid of your choice for a day or 2, clean the bottom of the hole, nice sharp bit, straight into the head, &c.
And where are you, exactly, that you can describe the weather anywhere in the States as "cold" ? 80 at 8 AM here for me.
- 4742 Views
Last post by EChem
- 10 Replies
- 6467 Views
Last post by 93Regina
- 766 Views
Last post by FlyingVolvo
- 263 Views
Last post by RickHaleParker
- 43 Replies
- 8825 Views
Last post by charlie33
