Seems likely.
Could have been a punk band......Oetiker Clamp.
Oetiker clamp information
Oetiker clamp Guide for P80 Volvos
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I added Volvo part number and Oetiker sizes for all the Oetiker clamps I've replaced. And some Norma Torro worm clamps because that's what the Volvo part number got me.850oldschool wrote: 11 Aug 2022, 13:56 If you find time to post the size and the Volvo part number it would pile your legendary status higher and deeper.
Anyone can reply with more Volvo part numbers and Oetiker clamp sizes and I'll add them to the first post.
FireFox31
This thread is like Sunshine on a Rainy Day.
What did the Oetikers do for summer Holiday?
CMon kids! Vee are going Clamping!
- Has thanked: 2857 times
- Been thanked: 1332 times
Entered into the VRD.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
This is the kit I ordered last year when I did my PCV system and my power steering line hose. (Might be a bit more than what's needed, but it's always nice to have extras. The case is also excellent for holding any new clamps to keep it topped off.)
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
That kit has 33.1's which will do the small side of the IAC, but you'll still need to buy a 36.1 for the large side. Also the large hose on the air pump uses a 36.1. Other than that (and CV boots) I think you're totally covered!
42 and 47 for radiator hoses. You need to load clamp on snout, then load hose, then fit clamp over the hose
On edit. I had trouble loading these on a car recently, maybe due to thickness variation in the Volvo new hoses?
I would recommend 44 and 48 mm with new hoses for easier install
Will document
Will document
- FireFox31
850oldschool wrote: 13 Aug 2022, 12:15 That kit has 33.1's which will do the small side of the IAC, but you'll still need to buy a 36.1 for the large side. Also the large hose on the air pump uses a 36.1. Other than that (and CV boots) I think you're totally covered!
Can you provide Volvo part numbers for the clamps you're referring to? Then I'll add them to the first post. I don't know what is the IAC or air pump, and I assumed the four clamps on the coolant hoses were the same size since they used the same worm clamp.abscate wrote: 13 Aug 2022, 16:58 42 and 47 for radiator hoses. You need to load clamp on snout, then load hose, then fit clamp over the hose
FireFox31
850oldschool
What other makers call the idle air controller (IAC), Volvo calls a "control slide" PN 9454745. If you look up that part number and then look at the associated diagrams, they depict a part and hose setup which looks quite different. It's poorly documented, maybe somebody smarter than me can find those part numbers. I just took the Oetiker numbers off the ones that were on it.
- FireFox31
Does anyone know the printed size range for the following Norma worm gear clamps. For instance, I think 988024 is Norma 16-27. Mine will likely be too rusty to read. These are for a 2000 V70 NA FWD auto.
Coolant reservoir bottom to coolant pipe (non-turbo), oil cooler x4 - 988024
Coolant pipe to HVAC heater core - 988025
Coolant pipe to lower coolant hose - 988030
Also looking for recommendations (manufacturer and part number) for a right angle Oetiker clamp tool and Oetiker clamp removal tool. The right angle tool would help with tight PCV clamps, inner tie rod boot clamps, and others which are hard to reach. I only found one (Lisle?) and it seems quite bulky, hard to get the head in tight spaces.
FireFox31
- 14 Replies
- 1612 Views
Last post by BEJinFbk
- 2198 Views
Last post by prwood
- 707 Views
Last post by MoVolvos
- 477 Views
Last post by jonesg
- 518 Views
Last post by firstv70volvo
