vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 604 times
Post by vtl »
br0dy519 wrote: 13 Aug 2022, 12:52 and drank lots of PBR
I filed a complaint with Odin in Asgard because of that misdemeanor (Pabst! Eww!!)
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
PBR=good
Natty Ice=bad
Don't do bad things. :lol: :lol: :lol:
Drink responsibly, and be safe working on whatever it may be.
br0dy519
Year and Model: 2004 XC70
Has thanked: 123 times
Been thanked: 115 times
Post by br0dy519 »
LOL, I just thought PBR and PB Blaster made a good pairing. I’m not picky with beer anymore, gone are the days that I pay $3 a can for the fancy stuff.
Forgot to mention earlier I also drove a tek screw into the heat shield above the muffler because it was hanging and causing a nasty rattle. I like when fixes are simple (and cheap) which seems rare these days.
04s60 2.4
04xc70 2.5t
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Sorry I haven't been very active lately, but it's been challenging finding time with my new job and all. Being out of the country for 3 weeks didn't help.
Before I went away I bought an 06' V70, base, auto, from a fellow forum member, Glenn. This car is replacing my 05' V70 5-speed manual. Glenn did a fantastic job keeping all the maintenance up to date. All I really had to do was change the oil.
Today I did a deep cleaning of the interior and started fixing a few little paint imperfections. I also installed the retracting cargo gate and fog lights. I also ordered a Weathertech cargo liner. Also, I swapped over the Canistos with almost new Conti tires and I think I will keep them on the car.
Next is polishing the headlights and installing the Laminex film I already have.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1836 times
Been thanked: 1709 times
Nice looking car!
When I did our son's XC70 headlights I removed the bumper and lights to get access to the edges.
850 LPT
Post by 850 LPT »
scot850 wrote: 13 Aug 2022, 20:21 Nice looking car!
Way too much effort this. Only Scots are THAT thorough :D
Not really, they had used some clear coat of some sort on them at some point which was a swine to remove. only way to get neat the edges on the XC was to remove them. I took the opportunity to swap all the minor bulbs out at the same time as the 2 that were out could not be removed otherwise. It was when I discovered the RH outer marker light is the only one that rotates counterclockwise to remove!!
dono
Year and Model: 04 V70&XC70 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by dono »
Control Arms, ball joints, outer tie rods, suspension stabilizer bar links, all brakes/pads/rotors + brake flush. Only hiccup was somehow got LF reluctor ring dirty and it threw ABS code. Also started out with wrong size front rotors (305mm too big). Lots of groveling under the car, super fun. When will I get too old to put up with the hassle? Im cheap so probably never :)
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi :D
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi :D
1999 Mercedes e320 4Matic 238k mi :D
2008 Toyota Avalon XL 165k mi (meh)
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
tested the brake fluid with $12 tester.
result speaks for itself.
br0dy519
Post by br0dy519 »
jonesg wrote: 09 Aug 2022, 14:19 I have same noises in my front end, sounds like something rubbing, checked dust shields etc, I think i'll let it ride til it gets unmistakable
or run it on front jackstands and listen with a stethoscope. Haldex fuse is pulled.
Is your noise sort of harmonic depending on vehicle speed, with intermittent vibration? I rode in the passenger seat today (is there anything more emasculating than being driven around by your wife? :lol: ) and it honestly sounds like the wheel bearing on the passenger side has gone too. Noise increases when braking or putting load on the right side. What a bugger!!!
04s60 2.4
04xc70 2.5t
