2002 v70 tighten ball joint
toshgregg
- Year and Model: 2002 V70 2.4t
bought a cheaper ball joint without spline socket in spindle and I cannot tighten the nut, spindle just spins. Jacked up control arm but still no luck, any ideas short of taking it apart and using a new joint with spline socket?
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Try an impact wrench, FYI the Volvo ball joints do not have a spline on the taper bore either. I assume you are talking about the large nut on the end of the balljoint?
2003 XC 70 (sold)
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Every single car I've seen has never had splines on the ball joint, the ball joint has a taper which when pressed in the knuckle well will hold it from spinning. Hammer it in from bellow.
deano1
- Year and Model: 2001 s60 1999 awd
- Has thanked: 13 times
- Been thanked: 17 times
He's talking about the torx "spline" Lemforder used on the bolt part of the ball joint. Sometimes you need to use this torx if the lock nut Lemforder supplied overwhelms the ball joints resistance to turn in it's socket before the nut is able to pull it tight to the control arm.
You all know this is amplified by 1000 if you're trying to remove that ball joint
cheers Dean
cheers Dean
- Blacklab467
Right, or use a channel lock plier or vice grip to hold the knuckle to the lower control arm, failing that, use the torx at the bottom of the ball joint spindle.
2003 XC 70 (sold)
You have to make sure that taper isn’t spinning. I made that mistake on an E83 and halfway home had a loose strut. Drove home at 45 on back roads , checking every 10 miles.
- 11 Replies
- 3195 Views
Last post by theWIFES_S70
- 16 Replies
- 2857 Views
Last post by mydamnvolvo
- 1947 Views
Last post by oragex
- 1799 Views
Last post by wizechatmgr
- 14 Replies
- 3085 Views
Last post by Miltown
