When a throttle body goes bad.....
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Can anyone please help me understand when it has been determined that a throttle body has gone bad, what actually has gone bad?
It looks to me from the outside more like a metal box with a wire harness coming out. More mechanical than electrical but I am most likely wrong there. Car has 178k miles on her and I am pretty sure this is the original throttle body.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
The P2 ETM has electric motor control of the throttle blade position. As feedback to the computer, a resistance film is used to sense the blade position and the film wears over time and fails.
Here is the MVS area for discussion of the ETM problem. https://www.matthewsvolvosite.com/volvo ... le-fiasco/
As discussed in the link, a good (although expensive) solution is the non-contact replacement ETM from XeMODeX. Used replacements have to match engine controls, so getting a used one is risky unless carefully selected.
XeMODeX has a flow chart to help determine if your problem is the ETM.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Quick question, is this problem still affecting say 2005 models? I recently attempted to steady the RPM at 2000 in neutral(Park mode), it was honestly difficult, as soon as I managed to get to 2000rpm, without moving my foot at all, the rpms ran away higher.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
My 04 S60 has a Denso throttle body that I have never had issues with. The Bosch throttle body in my 2004 XC70 went bad.... VERY bad. It was stuttering at highway cruise speeds, and finally one day threw a message on the dash "Reduced Engine Performance" and threw a VIDA code for the throttle body itself. Also, sometimes on startup, it would jump to like 4k RPMs then back down erratically.
The ETM (throttle module) is what most people refer to the 2001 Magnetti (or something Italian like that) branded throttle body that was a 100% failure rate. The Bosch (commonly referred to as the TB- throttle body) has a much smaller failure rate, but still has the mechanical component of the butterfly valve. It is still like an electric motor, with an actuator and gears, all of which are possible failure points. I took mine apartment and cleaned it multiple times but never got it ack to life. None of the electronics repair shops offer repair services for the Bosch throttle body.
@dikidera, the problem with your symptoms is that could be evident of a vacuum leak as well. I would suggest doing a good amount of troubleshooting prior to purchasing a new throttle body. Mine was very obviously the issue, but prior to diagnosing I also fixed multiple vacuum leaks. And gave the throttle body a very good cleaning, and verified the wiring harness continuity.
04s60 2.4
04xc70 2.5t
Has thanked: 1611 times
Been thanked: 4072 times
MTBF on the early ETM is something like 150k miles, earlier if you don’t keep it clean. The ETM is a software driven device so replacement involves both hardware and software matching, so it runs $750-1000, or you can get the Xmodex for $400+100core
The P2 uses a Electronic Throttle actuator which is just hardware. MTBF is quite a bit better..200k plus no software matching is needed, a new Volvo eta is a straight $500
