I recently replaced the AC/ Heater blower motor and when I pulled back the carpet for access there was water underneath the foam below the carpet. Would anyone have any Idea where this would be coming from?
Thank you
Blair Powley
09 XC90 water under front passenger carpet Topic is solved
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Clogged or compromised sunroof drain is the usual suspect, followed by a clogged cowl drain on the passenger side causing water to well up over the cabin intake air cover lip. Possible disconnected drain at the bottom of the blower enclosure but you just pulled the carpet so likely not.
Might be good to get the carpet up and out of the vehicle if you can as if you're seeing water on the floor the floor foam has probably gotten well soaked.
- Has thanked: 987 times
- Been thanked: 1075 times
Search MVS for test and repair of the sunroof drains.
- 1369 Views
Last post by bmdubya1198
- 10105 Views
Last post by michel23
- 602 Views
Last post by jonesg
- 1459 Views
Last post by oragex
- 9 Replies
- 2619 Views
Last post by Clemens
