Clicking noise coming from engine (2002 v70)
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
After I put the engine back together after replacing the head gasket, and after a few weeks, I started hearing a ticking noise coming from somewhere. I have attached a video file with the noise. The noise only happens on idle, and goes away when driving or reving. I think it happened because I put something together wrong. It sounds like it may be coming from where all the pullys and belts are.
volvoNoise.m4v
(4.43 MiB) Downloaded 142 times
2002 v70 X/C 288k miles
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
i'd pull the timing belt cover and watch the belt at idle.
02V70
Post by 02V70 »
I pulled the cover and didn’t see anything different happening when there was a clicking noise. However, I did notice it only happens when the A/C is on. I can’t really tell where the noise is coming from, but it doesn’t sound like it’s coming from the compressor. I attached a video showing the noise coming and going with the a/c compressor.
Img 1174.m4v
(6.25 MiB) Downloaded 103 times
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
To me it is a viberating sound from plastic material -- loose belt cover housing, not properly fastened. A careful look at the edges of the belt may not be a clue, but the belt tensioner may provide a clue.
Engine Timing Cover Casing:
jonesg
Post by jonesg »
does the aC blow cold air, sounds like the clutch isn't fully engaging
02V70
Post by 02V70 »
The A/C seems to work intermittently.
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 119 times
Been thanked: 15 times
Post by Jonboy74 »
02V70 wrote: 07 Sep 2022, 10:46 The A/C seems to work intermittently.
You might want to have a look at the compressor cycling. I personally ended up having a weak clutch and had to do the “bread clip” trick (though I used cable ties instead) to get it cycling properly.
Jonboy
jonesg
Post by jonesg »
there ya go then.
Get a strong light and watch the AC clutch, its probably not locking , just clicking.
